[SOLVED] “Tranquil IT” is not a trusted certificate
cefinformatique
Registration: May 26, 2023 - 2:25 p.m.
February 14, 2024 - 10:13
When I try to update a package from the store, I get the following error:
Signataire Tranquil IT. Aucun des certificats suivants ne permet de vérifier la signature : self-signed certificate "Tranquil IT" is not a trusted certificate.
cefinformatique
February 15, 2024 - 09:49
The problem is solved.
The "Directory of authorized external certs" field needed to be filled with "C:\Program Files (x86)\wapt\trusted_external_certs" in the wapt-templates repository settings.
February 15, 2024 - 4:07 PM
Hi Marc,
thanks for the feedback. :-)
That said, the value should have been updated automatically during the upgrade... Could you please tell us the upgrade path you used to get to this point so we can see how to prevent this from happening?
Regards,
