[SOLVED] filter on "waiting to reboot"
guigeek
Registration: Nov 21, 2017 - 9:21 p.m.
February 14, 2024 - 10:16
Hello everyone,
is it possible to filter machines that are waiting to restart following a Windows update?
I tried looking directly through the reporting and database fields, but I can't find the right field.
Can you point me in the right direction?
Thanks in advance!
Guillaume
February 14, 2024 - 4:33 PM
in the hardware inventory you will find the value:
reboot_needed.
You can drag and drop this value into the columns.
guigeek
February 14, 2024 - 5:10 PM
Great! Thanks!
