[SOLVED] Console crash
gbt
Registration: February 28, 2017 - 08:46
February 19, 2024 - 09:11
Hello everyone,
for the past few days my wapt-2.2.1.11899 Discovery console on Windows 10 (with a wapt server of the same version on Windows Server 2016) has been crashing 20 seconds after clicking on the "Private Repository" tab.
I've run wapt-scanpackages.bat on the server (it finished without errors), rebooted the server... but nothing works; my console closes every time I try to access the local repository.
There's no unusual information in the console or server logs.
I'm sending out a message in a bottle.
Thanks,
Olivier
February 19, 2024 - 10:44
Hello Olivier,
I believe this is related to the retrieval of new versions available on LUTI, which wasn't correctly handling the proxy configuration in version 2.2. The change in behavior would then be due to a change in the network configuration.
If this is indeed the bug, it has been fixed in subsequent versions of WAPT.
That said, WAPT version 2.2 is no longer supported as of January 2024 [1]. Upgrading is strongly recommended. :-)
Best regards,
[1] https://www.wapt.fr/en/doc-2.5/wapt-enterprise.html
