[SOLVED] Installing the FlameShot package
scarf
Registration: Nov 22, 2023 - 3:27 p.m.
February 21, 2024 - 4:33 PM
WAPT Server: Debian 11
WAPT version: 2.4.0.14143
Console: Windows 10
Hello, I'd like to ask a question on the forum. To give you some context, we want to replace GreenShot with FlameShot.
Since the package is not available on your repository, I then download the MSI which I store in C:\FlameShot.
I generate the package by specifying the path and then edit it.
I add the following line
run('msiexec /norestart /q /i "Flameshot-12.1.0-win64.msi"')
Then I tested a manual installation first, and it worked.
Next, I want to build the package, so I run it, and that's when the problems start: FATAL ERROR
I tried it without editing it; it builds fine, but it fails to install on the agents. I've attached a screenshot of the error and the Python code. Thank you for your help
Commander
2024-02-21 16_23_04-PyScripter - C__waptdev_rpb-flameshot_12.1.0_Windows_PROD_setup.py.png
2024-02-21 16_23_04-PyScripter - C__waptdev_rpb-flameshot_12.1.0_Windows_PROD_setup.py.png (29.75 KB) Viewed 18418 times
2024-02-21 16_25_40-PyScripter - C__waptdev_rpb-flameshot_12.1.0_Windows_PROD_setup.py.png
2024-02-21 16_25_40-PyScripter - C__waptdev_rpb-flameshot_12.1.0_Windows_PROD_setup.py.png (5.22 KB) Viewed 18418 times
February 21, 2024 - 5:43 PM
Hi Romain,
"build upload" is a deprecated method; we'll remove it from the menu to avoid confusion.
We need to remove the build-upload action from PyScripter. The method to upload the package now is to go to:
"Private Repository" -> "Import a Package" -> "Build and Import a Package,"
then select the corresponding working directory in WaptDev.
Regards,
February 21, 2024 - 5:52 PM
Hi again Romain,
I'd also like to add that it's preferable to use PyScript 3 for package creation (PyScript 4 has issues in some cases, particularly with code completion).
Furthermore, in your code you call both the `install_msi_if_needed` command and a `run('msiexec')` command immediately afterward. The first function runs `msiexec`, so the second line isn't necessary.
Best regards,
scarf
February 22, 2024 - 08:54
Hello, thank you for your replies. I tried the method with building and importing a package from the repository, and there were no errors. However, it would have been too easy!
When I deploy it to my machine to test, the package installs correctly on WAPT but not on my machine…
Note that installing and removing it works fine in PyScripter.
I've attached screenshots for better understanding
. Regards
Screenshot 2024-02-22 085329.png (147.13 KB) Viewed 18396 times
2024-02-22 08_52_21-WAPTConsole Enterprise version 2.4.0.14143.png (37.89 KB) Viewed 18396 times
italbot
Registration: Sep 26, 2023 - 3:50 p.m.
February 22, 2024 - 11:33
When I tried it on my end with the following lines of code, there were no errors and the application was correctly installed with the shortcuts in the menu:
    # Installing the software
    print("Installing: Flameshot-12.1.0-win64.msi")
    install_msi_if_needed('Flameshot-12.1.0-win64.msi')
Except in exceptional cases, there is no need to add any other command lines for the installation of an msi file.
Ingrid
scarf
February 22, 2024 - 12:10
italbot wrote: ↑Feb 22, 2024 - 11:33 Good morning,
Ingrid
Hello, when you push the package to your agents, do you encounter any problems? I tried it myself, even without modifying the code, and it still won't install. :/
Regards
italbot
February 23, 2024 - 10:13
It is indeed installed correctly; however, the shortcuts are located at the administrator user level. If you want them to appear in the menu on the user's computer, you can add the following line to def install():
create_programs_menu_shortcut("Flameshot", makepath(programfiles, "Flameshot","bin", "flameshot.exe"))
And to then delete the shortcut:
def uninstall() :
remove_programs_menu_shortcut("Flameshot")
Ingrid
scarf
February 26, 2024 - 09:14
thank you Ingrid, I've fixed the problem.
Have a good day everyone.
Regards.
