[SOLVED] Problem downloading a restricted access package
Christophe
Registration: June 5, 2018 - 8:31 AM
February 22, 2024 - 12:40
Since upgrading to version 2.5.4, I can no longer download restricted access packages (for example tis-oracle-java8-jre-nonfree).
I get this error message:
WAPT Java error.png (10.68 KB) Viewed 6381 times
However, I have no problem with the "tis-geany" package
I would like to clarify that my token is correctly registered and that I had no problems with the previous version of WAPT (2.4)
Where could the problem be coming from?
THANKS,
Christophe
February 22, 2024 - 4:14 PM
We noticed a problem with a popup not displaying in the console during duplication where validation wasn't performed.
Could you try downloading it from the web interface: https://wapt.tranquil.it/store/fr/tis-o ... re-nonfree?
I assume the interface will ask you for validation.
Christophe
February 23, 2024 - 09:12
Yes, after requesting the download, I was able to download it from the console.
The problem is solved.
Thank you and have a good day,
Christophe
