WAPT server: 2.4 Debian 11 Bullseye
Console Admin: Windows 10, WAPT 2.4
FlameShot package
Hello, as I don't have much knowledge of PyScripter, I would like to add a line to the FlameShot package configuration that would automatically add the software shortcut to \AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup to launch FlameShot automatically at startup.
Can you help me?
Thank you in advance
[SOLVED] PyScripter shortcut
- WAPT Expert
Hello Romain,
It's better to put it in the machine's startup menu rather than the user's, unless you want to allow users to delete it.
create_programs_menu_shortcut('test',target=makepath(programfiles, "Flameshot","bin", "flameshot.exe"),folder='StartUp'Denis
Hello, with the help of my superiors and you, I've created a working script that installs the application and adds a shortcut to the Windows taskbar and the Startup folder for all users of the computer. I'm sharing the code here for anyone who might be interested.
Regards
Regards
import subprocess
r"""
# Déclaration des variables globales - Avertissements : 1) Le contexte WAPT n'est disponible que dans les fonctions de paquet ; 2) Les variables globales ne sont pas persistantes entre les appels
# Déclaration des variables locales
# Installation du logiciel
print("Installation : Flameshot-12.1.0-win64.msi")
install_msi_if_needed('Flameshot-12.1.0-win64.msi')
# Chemin vers le dossier de démarrage commun pour tous les utilisateurs
all_users_startup_folder = os.path.join(os.getenv('ProgramData'), 'Microsoft', 'Windows', 'Start Menu', 'Programs', 'Startup')
# Création du raccourci dans le dossier de démarrage commun pour tous les utilisateurs
create_programs_menu_shortcut("Flameshot", makepath(programfiles, "Flameshot", "bin", "flameshot.exe"), folder=all_users_startup_folder)
# Lancement de Flameshot
print("Lancement de Flameshot...")
subprocess.Popen(makepath(programfiles, "Flameshot", "bin", "flameshot.exe"))
# Suppression du raccourci du dossier de démarrage commun pour tous les utilisateurs
remove()
def remove():
# Chemin vers le raccourci dans le dossier de démarrage commun pour tous les utilisateurs
shortcut_path = os.path.join(all_users_startup_folder, "Flameshot.lnk")
# Vérifier si le fichier du raccourci existe, puis le supprimer
if os.path.exists(shortcut_path):
os.remove(shortcut_path)
print("Raccourci supprimé avec succès.")
print("Le raccourci n'existe pas.")
- WAPT Expert
Hi Romain,
thanks for the feedback,
I'm marking the topic as RESOLVED.
