[SOLVED] Update problem with secondary repositories
guigeek
Registration: Nov 21, 2017 - 9:21 p.m.
March 15, 2024 - 1:32 PM
I have a problem with my secondary repositories; they are synchronized correctly, but the workstations are not seeing the updates.
I noticed the following in the logs:
"CRITICAL Error merging Packages from wapt into db: None : None"
Any ideas?
Thanks in advance,
Guillaume
guigeek
March 20, 2024 - 10:44
does anyone have any ideas about this problem?
Thanks!
guigeek
March 20, 2024 - 1:05 PM
I forgot to mention that the error appears in the logs of the wapt client in version 2.5.4.15342
guigeek
March 20, 2024 - 3:06 PM
It's okay, it's resolved :P
March 20, 2024 - 3:22 PM
Hi Guillaume,
I hadn't followed up on the question because the problem didn't really ring a bell. Out of curiosity, what was the issue? :-)
guigeek
March 20, 2024 - 3:47 PM
I had forgotten that I had set up firewall rules on each of the client machines... but I had forgotten to include the secondary repositories in my rules...
March 22, 2024 - 09:57
Thanks for the feedback. :-)
We could add the option to open firewall rules on remote Windows repositories to the package, though. -
