Context:
WAPT version: 2.2.3 Enterprise
Server OS: Debian 12
Administration console OS: Win10pro
Package development workstation OS: Win10pro
Is it possible to pass parameters between different WAPT packages?
For example: a PAKWAPT1 package returns the string 'chaineapasser' via the install function (and a return statement), and a PAKWAPT2 package tries to retrieve the string 'chaineapasser' by calling the WAPT.install function:
mavariableaassigner = WAPT.install( ['PAKWAPT1'], force = True)
This example doesn't work, but perhaps there's a mechanism to make it work?
Best regards,
Christophe.
[SOLVED]: Passing parameters between WAPT packets
croquebert
- Registration: March 30, 2022 - 5:41 PM
- WAPT Expert
Hi Christophe,
I don't think the return value of the install() function can be used that way.
However, you can create a file and store the value in question. If it's a value that shouldn't be shared, you can store it in the private directory of wapt.
Regards,
Regards,
croquebert
Hello Denis,dcardon wrote: ↑Apr 10, 2024 - 4:59 PM Hello Christophe,
I don't think the return value of the install() function can be used in that way.
Regards,
Thank you for your feedback.
I tried to retrieve the return value without success (with a MAVARIABLE = WAPT.install('PAQUETCHARGEUTILE')) without success.
The idea was to retrieve a payload emitted by a package to be exploited without having to use the file system.
The issue can be considered resolved.
Christophe
- WAPT Expert
Thanks for the feedback, Christophe
