[SOLVED] .NET 6 and 7: The x64 version contains an extra x86 version
t.heroult
Registration: December 8, 2020 - 10:13 AM
April 15, 2024 - 11:03
I've noticed that for the last two versions, the x64 versions of dotnet include both x64 and x86 files (even though there's a separate x86 version).
As a result,
dotnet 7.0.17 and 7.0.18, and
dotnet 6.0.28 and 6.0.29
are now over 100 MB instead of less than 50 MB.
Regards,
Tom
Consoles: Windows 10 & 11
Infrastructure: Windows
jpele
Registration: March 4, 2019 - 12:01
April 15, 2024 - 2:43 PM
This is intentional; both can be necessary for applications to function, and there's no way to definitively identify which one should be used. One application might use x64 or x86, while another application might very well need the other arch.
Regards,
Jimmy
t.heroult
April 15, 2024 - 4:11 PM
OK, I understand.
But in that case, why not have an 'all' package?
jpele
April 15, 2024 - 4:28 PM
This was the case before, but it caused problems in some situations. Therefore, we migrated to this solution, which is the most functional. You can absolutely modify the package to suit your needs.
