[RESOLVED] OS Deployment
Tchoko
Registration: Apr 07, 2024 - 4:48 p.m.
April 21, 2024 - 12:41 AM
I've configured the OS deployment and I'm getting the error below. Thank you in advance for your usual help.
Regards
April 21, 2024 - 2:01 PM
It seems you're trying to boot with "Windows Boot Manager."
WAPT uses IPXE, and "Windows Boot Manager" doesn't support IPXE.
https://forum.ipxe.org/showthread.php?tid=10729
You should boot into PXE via the BIOS, not through "Windows Boot Manager."
Tchoko
April 24, 2024 - 11:19
Noted. Thank you.
The issue can be closed.
