using wapt enterprise 2.5.4.15342
on a Debian server
with a Windows 10 package.
As the title indicates, I deployed the tis-audit-local-admins package.
It works very well, in that it correctly reports information about local administrator users and groups.
This information is displayed in the package's audit status tab. However, the "audit status" section remains in error.
Consequently, if I try to deploy this package to all machines in the network, they will all show an audit error.
Is it possible to fix this problem within the package itself?
Or
is there an SQL query I can add to the reporting tab to retrieve the names of local administrators by PC name?
Thank you in advance.
Best regards,
[RESOLVED] tis-audit-local-admins in audit error
- WAPT Expert
Hello Benoît,
The package allows you to define a list of authorized local admin users.
If the package finds an authorized local administrator, it won't throw an error. However, for unauthorized local administrators, they need to be removed; that's the purpose of the audit that triggers an error/warning
allowed_admins_list = [
rf"{get_computername()}\tisadmin",
rf"{domain_name}\tis-adm",
Hello dcardon,
Thank you for your reply. I hadn't seen that list.
It does indeed solve the problem mentioned earlier.
Another question:
I have some local admin accounts that are named. This account list is likely to change.
To avoid rebuilding the package with each change, would it be possible to allow all accounts that begin with "administrator_local_"?
Regards,
Another question:
Regards,
- WAPT Expert
Hello Benoît,
the code needs to be modified at the level of
And then change the package name to prevent the console from prompting you to upgrade to the next version that will be released on the store
(which would overwrite your changes)
for user in admins_users:
if not user.lower() in allow_admin:
listerror.append(user)
Thanks for your response.
I modified the for loop.
However, without understanding why, all admin accounts (authorized or not) were going into the error list.
I reversed the if loop, and now it works.
listerror = []
admins_users = local_group_members(name_group_admin)
if user.lower() in allow_admin or user.startswith(rf'{domain_name}\*********'):
pass
if listerror:
print (f'Les comptes administrateurs suivants ne sont pas autorisés :{listerror}') # Bad users in admin list:
return 'ERROR'
print('%s' % ','.join(admins_users)) # Allowed users in admin list:
return 'OK
