Hello.
In the console (v1.3.5), the "groups" display column is now empty.
Any ideas?
Thanks
, Raphaël Larronde
Group display problem
Re.
Yes, the names are there, in var/www/wapt in my case.
The Holy Spirit must be called Raphael, me in this instance... I don't know when it started, but I think it's after the server change, switching from a Windows server to Debian.
I'm attaching screenshots.
- Attachments
- wapt1.png (124.69 KB) Viewed 9839 times
- wapt2.png (112.26 KB) Viewed 9839 times
- wapt.png (199.27 KB) Viewed 9839 times
Raphaël Larronde,
Saint Joseph High School
, 64240 Hasparren
, 64240 Hasparren
Yes,
indeed, there's a good chance that's the reason.
I think that when you migrate from one to the other, certain parameters are lost, including the group, unless the personal packet on each machine carries this information (to be confirmed).
Just out of curiosity, why did you switch from one to the other?
There's a chance, but I created new package groups and they don't appear either. Weird.
The Windows server version works perfectly, but the PC was also used as a backup for our educational server. So I installed OpenMediaVault (which is Debian-based) instead of Windows 10, and WAPT as well.
I already asked TIS about this; here's their reply: "There are many advantages to having a Debian server instead of Windows...
but it's also a matter of habit:
- quick to install (a very basic 32-bit Debian + the tis-waptserver package which installs the dependencies)
- lighter "hardware" requirements (a Debian Wapt server: 256MB of RAM, 30GB of disk space for the Wapt packages. A "current" Windows server is a bit more...). We've set up Wapt servers on Raspberry Pi equivalents running Debian.
- easy to duplicate: rsync is enough
- easy to back up: rsync is enough... -> tisbackup
- easy to administer (ssh...) and update (apt...)
- no Windows license to purchase and manage, although for some administrations, it's not expensive.
And for those who don't yet know Debian, it's a good opportunity to try it...
Hubert TOUVET"
Hubert TOUVET"
Raphaël Larronde,
, 64240 Hasparren
, 64240 Hasparren
Hi again,
thanks for the reply. The advantages are actually the flexibility of administration and the environment that Linux offers compared to Windows, which is significant. But in my case, the future managers don't want to deal with Linux; they're allergic to it. ^^
Let me know if your problem gets resolved.
Best regards.
Best regards.
