[SOLVED] tis-enable-bitlocker: does not recognize uefi
t.heroult
Registration: December 8, 2020 - 10:13 AM
April 30, 2024 - 11:00 AM
Good morning
I don't understand where the following problem comes from:
On several machines, the packet failed with the following message:
  File "C:\WINDOWS\TEMP\waptry_hdetw\setup.py", line 72, in install
  File "C:\Program Files (x86)\wapt\waptutils.py", line 1957, in error
waptutils.EWaptSetupException: Fatal error : ERROR: This computer BIOS does not boot in UEFI mode, you have to change BIOS mode to continue
In the code, I see that it is the Get-ComputerInfo command that is used when searching for the "BiosFirmwareType" property (with uppercase pass).
On these PCs, I enter Get-ComputerInfo and the property is indeed "Uefi".
So, I don't understand, it seems the package isn't retrieving the property...
Any ideas?
Server: WAPT Enterprise 2.6.1.17786 on Debian
Consoles: Windows 10 & 11
Infrastructure: Windows
May 3, 2024 - 4:02 PM
Hi Thomas,
sorry, there's a regression in the run_powershell function with a mix of stderr and stdout. Simon is looking into it.
Regards,
t.heroult
July 12, 2024 - 10:42
Hi, I was just checking in on this matter.
July 12, 2024 - 11:25
Isn't it better since the last release?
To check:
C:\Windows\System32>waptpython
Python 3.8.19 (default, Jun 17 2024, 12:30:39) [MSC v.1929 32 bit (Intel)] on win32
>>> from setuphelpers import *
>>> get_powershell_str("Get-ComputerInfo", "BiosFirmwareType").upper()
'UEFI'
July 25, 2024 - 09:40
Hi Thomas,
did Simon's fix resolve the issue for you so I can mark the topic as resolved? :-)
Regards,
t.heroult
August 5, 2024 - 4:04 PM
That seems OK
. Thanks.
