[RESOLVED] Download updates as soon as they are available
PaulSLA
Registration: Oct 10, 2023 - 11:23
May 6, 2024 - 09:33
Is it possible to configure WAPT to automatically download package updates as soon as they are available, but only install them when the computer is shut down? This functionality would be similar to the "Download packages locally" option when manually checking for updates.
Our problem is that laptop users tend to shut down their devices, put them in their bags, and leave, which prevents updates from installing correctly. The idea would be for the packages to download while the computer is in use, and for the installations to take place when the computer is shut down (these installations could be performed without an internet connection).
May 6, 2024 - 11:22
Hi Paul,
the WAPT agent checks for updates and downloads the necessary packages every two hours by default.
However, if you use WAPT.install('my_package') in one of your conditional packages, the agent has no way of knowing in advance before installing the package that it needs to download it. Therefore, it will only be downloaded when the installations start, i.e., when the workstations are shut down. We are currently working on a syntax solution for this issue.
Best regards,
PaulSLA
May 13, 2024 - 10:58
Very well, thank you for your reply.
May 13, 2024 - 12:35
Hi Paul,
thanks for the feedback :-) , I'm marking the topic as RESOLVED.
Regards,
