I wanted to replace my Freemind package with TranquilIT's, but it depends on the Java8 package. And when I try to install Java8 on my test machines, I get this error:
Installing: dst-java8
WARNING: A Java Runtime Environment 8 (JRE) will be installed with WAPT since this package allow arbitrary install based on available package in a specific order
File "C:\wapt\common.py", line 4234, in install_wapt
File "C:\Windows\TEMP\waptj7f36gpx\setup.py", line 35, in install
File "C:\wapt\waptutils.py", line 1956, in error
waptutils.EWaptSetupException: Fatal error : ERROR: No Java Runtime Environment 8 (JRE) have been deployed on this system, please import and deploy the package adapted to your organization
