[SOLVED] waptselfservice group
May 6, 2024 - 2:20 PM
Oops, I just noticed that your server configuration isn't using waptserver-ldap.
Therefore, your authentication doesn't go through the WAPT server.
The login and password are given directly to Windows, and the group IDs are returned by Windows.
So yes, I would definitely bet on the lowercase group.
yann83
Registration: Apr 22, 2021 - 07:54
May 6, 2024 - 2:57 PM
Yes, the user account can see who is a member of
However, the group names are in uppercase; I'll try in lowercase
yann83
May 6, 2024 - 3:04 PM
It's working now, the package is displaying correctly.
I hadn't realized I needed to do the same as with any other package and link it to my machine to see its contents.
Sorry.
May 7, 2024 - 09:20
Hi Yann,
thanks for the feedback. We were looking quite far afield when it wasn't actually that complicated. :-)
Best regards,
