[RESOLVED] Screenpresso package
Christophe
Registration: June 5, 2018 - 8:31 AM
May 29, 2024 - 3:35 PM
WAPT version 2.5.4.15342 on Windows Server 2016
I'm trying to install the Screenpresso package but I keep getting an error regarding dependencies:
  File "C:\Program Files (x86)\WAPT\common.py", line 4065, in install_wapt
    raise EWaptUnavailablePackage('Missing dependencies: %s' % (','.join(missing_depends,)))
waptpackage.EWaptUnavailablePackage: Missing dependencies: dsi-dotnetfx
However, dotnetfx and dotnetfx4.8 are indeed present in my repository.
Is there a problem with the package?
THANKS,
Christophe
May 29, 2024 - 5:01 PM
Can you directly assign the dsi-dotnet and dsi-dotnetfx4.8 packages to the machine to see if that helps?
Christophe
May 30, 2024 - 08:02
By directly affecting the two Dotnetfx files (without Screenpresso), I still get the same error:
waptpackage.EWaptUnavailablePackage: Missing dependencies: dsi-dotnetfx4.8
What is the purpose of dotnetfx, as this package appears empty to me (only 8.2kb)?
May 30, 2024 - 09:21
Hello Christophe,
the tis-dotnet package is a meta-package that points to tis-dotnetfx4.8. This allows you to change the package and point to tis-dotnetfx4.9 when it's released without modifying all the dependent packages.
If you've assigned the package and it's not accepted by the agent, it means there's a capability matching issue (language, x32 vs. x64 architecture, etc.).
Regards,
Christophe
May 30, 2024 - 09:44
Oops, my bad.
I hadn't noticed there was a new dotnetfx4.8. I still had the old one in my repository (the one compatible with >=6.1).
By updating the package, everything now installs correctly.
Thanks and sorry for the mistake. Have
a good day,
Christophe
May 30, 2024 - 10:06
Hi Christophe,
thanks for the feedback :-), I'm marking the topic as resolved.
Feel free to spread the word about WAPT!
Best regards,
