[SOLVED] wapt console linux 2.5.4.15342
Welsh
Registration: December 6, 2022 - 9:44 AM
May 27, 2024 - 3:59 PM
I wanted to report a bug (display issue?).
When I upload a package via my Linux console (2.5.4.15342),
the upload itself goes smoothly. However, when I try to use this package from a Windows console,
not all of the package's properties appear in the dependency add window.
In fact, only the "package" name is displayed, with no other information (Section / Name / Description / Signatory / Signed on / Publisher, etc.),
whereas everything displays correctly in the "Private Repository" tab.
It's not a major problem at the moment, but since I'm increasingly using the Linux console, it could become an issue someday.
I haven't explored the application to see if this might affect other tabs.
Best regards,
Baptiste.
- 1 WAPT 2.5.5.15602 Enterprise server (3000 workstations) + 1 WAPT 2.4.0.14058 Enterprise server (10000 workstations)
- WAPT server OS: Linux REHL 8.7
- Administration/package creation machine OS: Windows Server 2019 v1809
May 27, 2024 - 5:16 PM
Hi Baptiste,
actually it's not a bug, but a feature, or at least a feature fix...
In WAPT's operation, the agent chooses the correct version of the package it will use, not the package selection window. To illustrate this, in the machine package, only the package name is added, not the OS version or the package version: the agent takes the latest available version based on the installation constraints (OS, OS version, language, etc.).
So, to be closer to reality, we stopped filling in the grid, because it could be misleading, and the information wasn't always correct (only the package name is guaranteed to be correct).
So this is normal, and it will work correctly even if you're using a Linux console, and whether you have Linux or Windows agents.
In a multi-platform environment, when importing packages in the "Import Packages" window, be sure to check the "Compatible with known machines" box. This will automatically select available packages based on the OS type/version/language/architecture present in your repository.
I hope this explanation is clear enough. :-)
Welsh
May 28, 2024 - 8:55 PM
Good evening Denis,
okay, I understand how it works better now,
thank you for this additional information ;-)
. Have a good evening.
Baptiste
June 3, 2024 - 9:50 AM
Hi Baptiste,
thanks for your feedback :-) , I'm marking the topic as resolved.
