[SOLVED] Winrar remove not working
sebastien4444
Registration: Sep 14, 2023 - 08:53
June 3, 2024 - 12:06
In order to test the creation of packages, I wanted to do a test with a software that seems quite simple in terms of installation: WinRar.
Following the package creation procedure in the YouTube video "Creating, configuring and deploying an exe package with WAPT", I therefore went through "Generating a package template" in the WAPT console.
When editing the setup.py file, I retrieved the uninstallation key via a command prompt:
C:\Users\seb>wapt-get list-registry winrar
Using config file: E:\wapt\wapt-get.ini
UninstallKey                           Software                                                              Version             Uninstallstring
WinRAR archiver                        WinRAR 7.01 (64-bit)                                                  7.01.0              C:\Program Files\WinRAR\uninstall.exe
I then entered this information into the install() function, resulting in the following setup.py file:
r"""
    # Declaring local variables
    # Installing the software
    print("Installing: winrar-x64-701fr.exe")
    install_exe_if_needed('winrar-x64-701fr.exe',
        silentflags='/S',
        key='WinRAR archiver',
        min_version='7.1.0'
    create_desktop_shortcut(r'WinRaR',target=r'C:\Program Files\WinRAR\WinRAR.exe')
When I run WAPT:install in the PyScripter project, Winrar installs correctly on my host machine BUT no shortcut is added to my current user's desktop.
When I run WAPT:remove, it doesn't uninstall WinRAR from my host, and I don't understand why :roll:
Below are the console outputs following the run of install and then remove:
Command Line : install "C:\waptdev\pilote-winrar_7.1.0_Windows_PROD-wapt\WAPT\.."
Installing WAPT files C:\waptdev\pilote-winrar_7.1.0_Windows_PROD-wapt
Installing: winrar-x64-701fr.exe (7.1.0)
Results :
 === install packages ===
  C:\waptdev\pilote-winrar_7.1.0_Windows_PROD-wapt | pilote-winrar (7.1.0-0)
Command Line : remove "C:\waptdev\pilote-winrar_7.1.0_Windows_PROD-wapt\WAPT\.."
Removing C:\waptdev\pilote-winrar_7.1.0_Windows_PROD-wapt\WAPT\.. ...
=== Removed packages ===
  pilote-winrar
June 3, 2024 - 12:37
sebastien4444 wrote: ↑June 3, 2024 - 12:06 When I launch a Run of WAPT:install in the PyScripter project, Winrar installs correctly on my host machine BUT no shortcut is added to my current user's desktop.
Not sure if WinRAR creates a shortcut?
Results :
  pilote-winrar
Based on the output, I assume the installation was not restarted after the key was added?
Note: Restarting the installation after adding the key is mandatory.
sebastien4444
June 3, 2024 - 1:38 PM
sfonteneau wrote: ↑June 3, 2024 - 12:37 Not sure if WinRAR creates a shortcut?
But shouldn't adding this line to the install() function force the addition of a shortcut?
sfonteneau wrote: ↑June 3, 2024 - 12:37 Based on the output, I assume the installation wasn't restarted after adding the key?
Note: restarting an installation after adding the key is mandatory.
I followed the steps in the YouTube tutorial correctly and therefore restarted the installation after adding the key.
I even ended up manually uninstalling WinRAR and reinstalling it using Run install, but it's still the same; running Run remove doesn't uninstall the software :?
June 3, 2024 - 1:42 PM
Yes, indeed, `create_desktop_shortcut` should create the shortcut; I hadn't noticed it.
And the uninstallation should work if you restart the installation correctly; I don't see any errors.
Do you see a message like "Exe setup %s already installed. Skipping" when you restart the installation?
June 3, 2024 - 1:56 PM
I just relaunched WinRAR on LUTI (the online version check wasn't working properly).
I can confirm that the package works; it installs and uninstalls.
Your case is interesting; I don't see where the problem lies.
sebastien4444
June 3, 2024 - 2:39 PM
Well, in the end I think the problem isn't with WAPT but rather with the environment I was working in.
I was doing these tests from a server where I had installed the console, and I was getting this behavior.
I finally installed the console on a test laptop, and there were no problems with my install/uninstall tests (tested with WinRAR and Thunderbird).
So the problem must be with the server environment I was initially using.
And on that server, I don't get the ".... already installed. Skipping" message when I reinstall a package that's already installed.
Sorry for wasting your time. :)
June 4, 2024 - 10:28
sebastien4444 wrote: ↑June 3, 2024 - 2:39 PM Sorry for wasting your time :)
Ultimately, this allowed us to correct our WinRAR check in Luti, which wasn't working properly, so no time was wasted ;)
