Error deploying package "tis-glpi-plugin-export-to-glpi"
Answer
Steph
Registration: June 3, 2024 - 2:44 PM
June 3, 2024 - 2:55 PM
I'm encountering a problem deploying the "tis-glpi-plugin-export-to-glpi" package.
I'm getting the following error:
Audited aborted due to exception: Authentication failed on server https://xxxxxxxx for action api/v3/login.
Have you encountered the same issue?
Thanks for any feedback
. Best regards,
Stéphane
June 3, 2024 - 5:39 PM
I don't have your version of Wapt (see forum rules) Windows/Linux etc.
You specify using: tis-glpi-plugin-export-to-glpi
But this one doesn't exist, it's either:
tis-glpi-plugin-export-to-glpi9
or
tis-glpi-plugin-export-to-glpi10
Which one are you using?
Steph
June 5, 2024 - 10:40
We are using the "tis-glpi-plugin-export-to-glpi10"
and WAPT server 2.5.5.15602.
I ran another test deploying to a different machine: same problem.
Thank you for your feedback.
June 5, 2024 - 11:09
On the machine that has the tis-glpi-plugin-export-to-glpi10 package,
have you modified the wapt_api.ini file?
On Linux:
/opt/wapt/private/wapt_api.ini
On Windows:
C:\Program Files (x86)\wapt\private\wapt_api.ini
A login and password must be entered here.
Steph
June 5, 2024 - 3:22 PM
I just configured the "wapt_api.ini" file
and it's perfect. OK,
thank you very much,
the topic can be closed as it is resolved.
Answer
