Error session-setup in the fix-disable-windows-update package
Answer
jlatieule
Registration: July 3, 2019 - 9:18 AM
June 6, 2024 - 3:44 PM
I am testing the fix-disable-windows-update package and I am encountering an error during session-setup
It appears that a non-existent key is modified on line 147
Here is the error message
C:\Users\latijoel>wapt-get session-setup ALL
Running session_setup for package ophlm-fix-disable-windows-update(=10.0-36) and user latijoel
2024-06-06 15:35:57,036 CRITICAL Fatal error in session_setup function: AttributeError: __enter__:
  File "C:\Program Files (x86)\wapt\waptpackage.py", line 2936, in call_setup_hook
    hookdata = hook_func()
  File "<string>", line 147, in session_setup
  File "C:\Program Files (x86)\wapt\setuphelpers_windows.py", line 3542, in registry_set
    with reg_openkey_noredir(root, path, sam=KEY_WRITE, create_if_missing=True) as key:
2024-06-06 15:35:57,053 CRITICAL session_setup failed for package ophlm-fix-disable-windows-update(=10.0-36) and user latijoel
31 packages configured for user latijoel
And here is the screenshot of the regedit file
I'm guessing it's just a matter of adding a key verification step. Is that correct?
System and Network Administrator at Domitia Habitat
Answer
