I'm having a strange problem with my Solidworks 2024 package. It installs correctly and uninstalls as well. But if I try to reinstall it on the same PC, it only "pretends" to install. The package's install() function doesn't return an error (auditing is disabled), but nothing actually reinstalls. If I run a manual installation of the same version of Solidworks, it installs correctly on the machine.
Here is the setup.py file:
app_name = 'SOLIDWORKS 2024'
app_dir = makepath(programfiles, 'SOLIDWORKS Corp')
app_dir_binaries = makepath(app_dir,'SOLIDWORKS')
binary_name = "SLDWORKS.exe"
kill_list = [binary_name]
print('Installation de : %s' % control.name)
install_exe_if_needed(r'SW2024\startswinstall.exe',silentflags='/install /now',timeout=1800)
# Remove software and all dependances installed by my custom Administrative SolidWorks Image. You should probably adapt this function to your Administrative Image.
print('Uninstalling CEF for SOLIDWORKS Applications')
run_notfatal(r'MsiExec.exe /X{A3731044-38ED-44A1-AA43-0819B422AADB} /passive /norestart')
print('Uninstalling SOLIDWORKS 2024 French Resources')
run_notfatal(r'MsiExec.exe /X{12E5ACE4-6D44-444C-BCA4-679A861D0711} /passive /norestart')
print('Uninstalling SOLIDWORKS eDrawings 2024 SP02.1')
run_notfatal(r'MsiExec.exe /X{3835B6E2-CC35-4F45-900A-5AE9772B8B24} /passive /norestart')
print('Uninstalling SOLIDWORKS Flow Simulation 2024 SP02.1')
run_notfatal(r'MsiExec.exe /X{5D202678-5697-45BE-B4DF-3208EBFE8415} /passive /norestart')
print(r'Desinstallation de SOLIDWORKS 2024 SP02.1')
run_notfatal(r'MsiExec.exe /X{E9661DF2-E1B0-423F-BFFA-1A6EF0B1307B} /passive /norestart')
print(r'Uninstalling SolidWorks Installation Manager 20240-40200-1100-100')
run_notfatal(r'"C:\WINDOWS\SolidWorks\IM_20240-40200-1100-100\sldim\sldim.exe" /remove "C:\WINDOWS\SolidWorks\IM_20240-40200-1100-100\sldim\sldIM_installed.xml"')
if reg_key_exists(HKEY_LOCAL_MACHINE,r'SOFTWARE\WOW6432Node\Microsoft\Windows\CurrentVersion\Uninstall\SolidWorks Installation Manager 20240-40200-1100-100'):
registry_deletekey(HKEY_LOCAL_MACHINE,r'SOFTWARE\WOW6432Node\Microsoft\Windows\CurrentVersion\Uninstall',r'SolidWorks Installation Manager 20240-40200-1100-100')
remove_tree(r'C:\Windows\Solidworks')
print(r'Remove extra folders and data')
remove_tree(r'C:\Program Files\SOLIDWORKS Corp')
remove_tree(r'C:\SOLIDWORKS Data')
remove_tree(r'C:\ProgramData\SOLIDWORKS')
def audit():
return("OK")EDIT: I think the problem stems from the missing "SW2024\64bit\sldim\admin.dat" file, which I removed from the package because it was causing a SHA not matching error (antivirus detection?). It should be recreated in the SW2024 folder just before installation.
