Hello TranquilIT,
Is there a way, in the wapt console (2.5.2), to display the status of workstations based on their assigned maturity level?
Currently, I use a dedicated package to assign them a PREPROD or DEV maturity level, and I filter by package to display them according to my needs.
Is this the correct method?
Isn't there a simpler way that I might have missed?
Thank you in advance
. Best regards.
[RESOLVED] Job search based on maturity
- WAPT Expert
Hello Etamin,
in the inventory tab, you can search for the value "host_capabilities/packages_maturities" on a machine in the hardware inventory, drag and drop it onto the main grid, and click refresh. Then you can sort the results in the grid.
Alternatively, you can query the maturity level and configure it to use as a filter.
Regards,
Regards,
