[SOLVED] WADS operation not supported error
tristan
Registration: June 10, 2024 - 3:39 PM
June 19, 2024 - 4:11 PM
we have WAPT Server running on Debian 12 and we want to use the WADS solution. We have configured the required DHCP options.
However, when booting the PC via IPXE, we get the following error: "Operation not supported".
After several searches and tests, we haven't found a solution.
Has anyone else encountered this problem?
June 19, 2024 - 5:34 PM
Hello
, have you enabled HTTPS redirection?
If so, the IPXE bootloader does not support HTTPS redirection.
tristan
June 20, 2024 - 10:46
After further research, I relaunched the post-installation script, making sure to enable the WADS service, which resolved my problem:
opt/wapt/waptserver/scripts/postconf.sh
June 20, 2024 - 11:54
Hi Tristan,
yes, it's important to rerun postconf after upgrades or when activating new features. This makes changes to the nginx configuration file that are essential for proper operation.
Thanks for your feedback. I'm marking the topic as resolved.
