I'm currently creating a prototype to see if the product meets the needs of a school. So far, the results are quite positive.
I'd like to deploy it using the waptdeploy tool via a GPO. I can't figure out how to generate the hash.
Any solutions?
Thanks.
How do I get the hash of Waptdeploy?
- WAPT Expert
On Linux: `sha256sum /var/www/wapt/waptagent.exe`
On Windows, the latest version of 7-Zip allows you to retrieve the hash.
Otherwise, during agent generation, the hash is located here: c:\wapt\waptupgrade\waptagent.sha256
