SSO self service is no longer working
Answer
tux
Registration: Sep 05, 2023 - 09:44
June 25, 2024 - 5:19 PM
SSO with self-service is no longer working (Windows 10 Enterprise client).
I'm not sure if this started after we migrated to version 2.5.5.15602.
It tells me the username or password is incorrect.
If I enter the correct username and password, it works.
In Firefox, if I configure network.negotiate-auth.trusted-uris, https://srvwapt.mydomain.lan/api/v3/login_kerberos works without any problems.
`success true`
`msg "Authentication OK"`
`request_time 0.0777885913848877`
My SSO configuration seems to be correct. Do you have any suggestions or areas to investigate further
? Should I check the log files?
Is this a known issue with this version of WAPT?
Thank you in advance.
Wapt Enterprise Edition 2.6.1.17765
WAPTConsole Enterprise on Windows
WAPT Server on Debian 12
tux
September 4, 2024 - 6:07 PM
I'm bumping this thread.
Do you have any ideas or suggestions?
Thank you.
Answer
