I would like to use the functionality offered by WAPT 2.5 for OS deployment.
Our DHCP infrastructure is managed by Efficient IP appliances.
Do you have experience deploying OS in this context for iPXE configuration?
Thank you.
[RESOLVED] OS Deployment / DHCP Configuration / Efficient IP Appliance
- WAPT Expert
For a minimal DHCP configuration, you can run:
`/opt/wapt/waptserver
/scripts/compile_ipxe.sh`. The script will create three files
: `ipxe_custom.efi` (for UEFI)
, `snponly_custom.efi` (for UEFI),
and `undionly_custom.kpxe` (for legacy).
In your Efficient IP Appliance, you can then configure a minimal PXE configuration:
`filename = snponly_custom.efi`
and `next-server = waptserverip`.
This minimal mode will allow you to deploy only UEFI machines.
- WAPT Expert
Hi Julien,
were you able to set up your configuration?
Regards,
Regards,
- WAPT Expert
Hello Julien,
thank you for your feedback. It's important on the forum to know that the topic is resolved for others who might come across it through a Google search or other means.
Regards,
Regards,
