Mesh Procedure
Answer
gch14800
Registration: July 23, 2024 - 09:01
July 24, 2024 - 3:21 PM
I saw that Mesh was available in the WAPT console, however, are there any specific requirements for WAPT to communicate with Mesh?
Thank you!
July 24, 2024 - 3:31 PM
Hi Guillaume,
you need to download the meshagent package [1], integrate your mesh agent, and then modify the configuration file to reflect your server's settings.
The package installs the agent and then performs regular audits to collect information from the mesh agent and enable a direct connection from the console.
Regards,
[1] https://wapt.tranquil.it/store/en/tis-m ... t-template
gch14800
August 6, 2024 - 09:47
Hello Denis,
Thank you very much, I will look at the contents of the package
Answer
