Deleting a file via session setup
Answer
jorico
Registration: August 11, 2022 - 4:42 PM
August 5, 2024 - 2:39 PM
Hello everyone,
I'm trying to create a package for installing the Asana application; the application needs to be installed in the user's environment, so I'm using a session setup:
setup.py
import time
import glob
r"""
bin_name = "AsanaSetup.exe"
bin_tempdir = makepath('C:\\temp')
binaries = makepath(bin_tempdir, bin_name)
user_app_dir = makepath(user_local_appdata, "Asana")
processes_to_kill = ["Asana"]
    # Declaring local variables
    print("Copying binaries in C:\temp")
    filecopyto(bin_name, bin_tempdir)
def session_setup():
    # Installing the package in user env
    print("Installing: %s in user env" % "Asana")
    install_exe_if_needed(binaries, killbefore="Asana.exe")
    register_windows_uninstall(control)
    time.sleep(20)
    remove_file(binaries)
    print("ASANA is Installed ")
    killalltasks(processes_to_kill)
    print("Uninstalling: %s in user env" % "Asana")
    unregister_uninstall("Asana")
However, the binary placed in C:\temp is not deleted at the end of the session setup, do you have any idea what my mistake is?
Thank you all for your help :)
WAPT Enterprise 2.5.5.15697
Server = Debian 11 Bullseye
Console = Windows Server 2019
Johan
t.heroult
Registration: December 8, 2020 - 10:13 AM
August 5, 2024 - 3:42 PM
silly question, but does the user have the right to delete a file from the temp folder?
Don't forget that session-setup is done with the rights of the current user.
Server: WAPT Enterprise 2.6.1.17786 on Debian
Consoles: Windows 10 & 11
Infrastructure: Windows
jorico
August 5, 2024 - 3:52 PM
t.heroult wrote: August 5, 2024 - 3:42 PM Hello,
Hello t.heroult,
Thanks for your question; I hadn't considered that point. The user has the right to delete the file in the C:\temp folder
I just checked, I'm getting an error after installation:
CRITICAL Exception: The database is locked. There is probably another WAPT process currently running (WaptAgent, WaptSelfService, wapt-get, waptpython.exe). Please check running processes. Error: OperationalError('database is locked')
Johan
t.heroult
August 5, 2024 - 4:10 PM
It's surprising to get this error during session setup; you'll have to wait for support to reply :)
August 14, 2024 - 1:22 PM
The OperationalError('database is locked') problem
often occurs when two WAPT processes are running concurrently.
For example, the service might be performing an update, and at the same time, you run `wapt-get upgrade` from the administrator command line.
Two processes are therefore trying to access the same database, resulting in the OperationalError('database is locked').
Answer
