Name our secondary depots
Answer
FlavienL
Registration: May 9, 2023 - 10:36
August 12, 2024 - 11:11
We are currently migrating our secondary repositories to Windows machines.
The agent correctly retrieves the computer's FQDN, but would it be possible to force a name like the site name "LeSite" in a column as specified below, for example, the description?
This would make it easier for us to locate the repository servers.
I've searched through the documents without success, do you have a solution?
Flavien
FlavienL
August 13, 2024 - 09:09
I'm taking this opportunity to bump the thread, or perhaps it could be in the machine name column, for example.
Regards,
Flavien
August 14, 2024 - 1:19 PM
Hello
, thank you for your feedback.
The problem has been fixed internally on the master server (some information wasn't displayed).
The description can now be added via the inventory tab (simply edit in the description field).
However, it wasn't displayed in the secondary repository tab; we've just fixed that.
- Simon
FlavienL
August 19, 2024 - 11:00
thank you Simon. Despite editing the field in the console inventory, it's not appearing in the inventory or in the secondary repositories.
The description column remains empty.
Perhaps this is because we're still on version 2.4?
Regards,
Answer
