Changes to HTTP/HTTPS ports on WAPT server v2.5 Debian 11
Answer
Maggle
Registration: March 20, 2024 - 2:22 PM
August 14, 2024 - 11:46
I have a WAPT server, version 2.5, installed on Debian 11.
To set up external access to the server from workstations via a shared network, I need to change the HTTP and HTTPS ports of my WAPT server.
I saw in the 2.5 documentation that this is possible on Windows by modifying the waptserver.ini file,
but I haven't found how to do it on Linux. I tried modifying configuration files, but without success.
Could you please tell me how to proceed?
August 14, 2024 - 11:54
Good morning
In :
/opt/wapt/conf/waptserver.ini
Add :
[options]
nginx_https  = 4443
nginx_http = 480
And relaunch a post-conference
This should work
Maggle
August 14, 2024 - 1:48 PM
Thank you for your quick reply.
Despite editing waptserver.ini and running postconf, I still cannot access my server (see attached image), whereas if I reset the ports to default (comment out the two added lines and run postconf) it works.
August 14, 2024 - 2:02 PM
What does this give?
netstat -pnat |grep nginx |grep "0.0.0.0"
Has nginx been restarted?
You wouldn't happen to have an additional firewall blocking access to the new port, would you?
try on the server:
curl https://127.0.0.1:8443 --insecure
Answer
