[SOLVED] WAPT WUA HTTPError: 503
ravichandran
Registration: Sep 4, 2024 - 11:36
September 4, 2024 - 12:51
I'm having a problem with WAPT Windows Update.
WAPT Server version: 2.5.5.15691
HTTPError: 503 Server Error: Service Unavailable for url: http://download.windowsupdate.com/micro ... usscn2.cab
How can I fix this problem?
September 4, 2024 - 1:09 PM
Good morning
Does it work if you download it manually from your browser?
Does it work if you run this command from the server?
curl http://download.windowsupdate.com/microsoftupdate/v6/wsusscan/wsusscn2.cab -o wsusscn2.cab
Are you using a proxy?
Windows/Linux server?
ravichandran
September 20, 2024 - 3:02 PM
Problem solved.
The VLAN on which the WAPT server was installed did not have access to the Microsoft website for downloading CAB files.
Access is now restored and everything is working normally.
Thank you for your help
. Best regards,
Ravichandran
