Package "Cumulative Update for .NET Framework for Windows 10, version 1809 and Windows Server 2019"
Answer
jlatieule
Registration: July 3, 2019 - 9:18 AM
September 18, 2024 - 11:41
I just created a package to perform the "Cumulative Update for .NET Framework 3.5, 4.7.2 and 4.8 for Windows 10, version 1809 and Windows Server 2019"
https://support.microsoft.com/fr-fr/top ... f09e30fcf3
More specifically, KB5042350 dated August 13, 2024
Depending on whether it's .NET Framework 4.8 or later, the msu file is different.
The versions can be found in the registry; more information on https://learn.microsoft.com/fr-fr/dotne ... -installed
Best of luck to everyone
import re
r"""
    with EnsureWUAUServRunning():
        # Choix du MSU en fonction du .NET Framework
        if registry_readstring(HKEY_LOCAL_MACHINE,'SOFTWARE\\Microsoft\\NET Framework Setup\\NDP\\v4\\Full','Release') >= '528040' :
            # .NET Framework 4.8 ou plus
            kb_files = [
                'windows10.0-kb5041974-x64-ndp48_e8660214346c8ac124e2f99aa21eef697fff307d',
            # .NET Framework 3.5 à 4.7.2
            kb_files = [
                'windows10.0-kb5041913-x64_b00cd2de1915f11b56c21d7001962f67854afe07.msu',
        for kb_file in kb_files:
            kb_guess = re.findall(r'^.*-(KB.*)-',kb_file)
            if not kb_guess or not is_kb_installed(kb_guess[0]):
                print("Installation de {}".format(kb_file))
                run('wusa.exe "{}" /quiet /norestart'.format(kb_file), accept_returncodes=[0, 3010, 2359302, -2145124329], timeout=1800)
                print("{} est déjà installé".format(kb_file))
    if is_pending_reboot():
        print("Un redémarrage est nécessaire !")
System and Network Administrator at Domitia Habitat
jlatieule
September 18, 2024 - 11:49
However, on servers with .NET Framework 4.8 installed, the MSU installation returns an exit status of 2
If I run the installation graphically, I don't get an error message... but if I restart the installation, I get the message that the message is already installed
Here is the installation log, and I don't know how to improve the situation
Ensure wuauserv Auto Update option is disabled
Installation de windows10.0-kb5041974-x64-ndp48_e8660214346c8ac124e2f99aa21eef697fff307d
re-enabling wuauserv previous state: 0
Erreur lors de l'installation de ['ophlm-kb5042350(=1.1.0-4)']: erreurs dans les paquets [[PackageRequest(package='ophlm-kb5042350',version=(Version('1.1.0.0'), 4),architectures=['x64'],locales=['fr'],maturities=['PROD'],tags=['windows-10', 'win-10', 'w-10', 'windows10', 'win10', 'w10', 'windows', 'win', 'w'],min_os_version=Version('10.0.17763'),max_os_version=Version('10.0.17763')), PackageEntry('ophlm-kb5042350','1.1.0-4' architecture='x64',maturity='PROD',target_os='windows'), 'Traceback (most recent call last):\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 5348, in install\n    result = self.install_wapt(p.localpath,\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 4328, in install_wapt\n    raise e\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 4235, in install_wapt\n    exitstatus = setup.install()\n  File "C:\\Windows\\TEMP\\waptxgn6fxcm\\setup.py", line 28, in install\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 3991, in run\n    return ensure_unicode(run(*arg, pidlist=self.pidlist,**args))\n  File "C:\\Program Files (x86)\\wapt\\waptutils.py", line 2177, in run\n    raise CalledProcessErrorOutput(proc.returncode, cmd, \'\'.join(output))\nwaptutils.CalledProcessErrorOutput: Command \'wusa.exe "windows10.0-kb5041974-x64-ndp48_e8660214346c8ac124e2f99aa21eef697fff307d" /quiet /norestart\' returned non-zero exit status 2.\nOutput:\n']]
    self._run()
Exception: Erreur lors de l'installation de ['ophlm-kb5042350(=1.1.0-4)']: erreurs dans les paquets [[PackageRequest(package='ophlm-kb5042350',version=(Version('1.1.0.0'), 4),architectures=['x64'],locales=['fr'],maturities=['PROD'],tags=['windows-10', 'win-10', 'w-10', 'windows10', 'win10', 'w10', 'windows', 'win', 'w'],min_os_version=Version('10.0.17763'),max_os_version=Version('10.0.17763')), PackageEntry('ophlm-kb5042350','1.1.0-4' architecture='x64',maturity='PROD',target_os='windows'), 'Traceback (most recent call last):\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 5348, in install\n    result = self.install_wapt(p.localpath,\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 4328, in install_wapt\n    raise e\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 4235, in install_wapt\n    exitstatus = setup.install()\n  File "C:\\Windows\\TEMP\\waptxgn6fxcm\\setup.py", line 28, in install\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 3991, in run\n    return ensure_unicode(run(*arg, pidlist=self.pidlist,**args))\n  File "C:\\Program Files (x86)\\wapt\\waptutils.py", line 2177, in run\n    raise CalledProcessErrorOutput(proc.returncode, cmd, \'\'.join(output))\nwaptutils.CalledProcessErrorOutput: Command \'wusa.exe "windows10.0-kb5041974-x64-ndp48_e8660214346c8ac124e2f99aa21eef697fff307d" /quiet /norestart\' returned non-zero exit status 2.\nOutput:\n']]
    self._run()
September 20, 2024 - 1:09 PM
Good morning
The following command should be run:
It clearly doesn't work on the machine
If you then remove the /quiet, you will likely get an error message explaining why it's not working
jlatieule
September 25, 2024 - 3:16 PM
I didn't understand why it worked when the command was executed on the server.
I had forgotten the file extension for the .msu file in setup.py.
The problem is solved.
Answer
