[RESOLVED] Secondary repositories not functioning
Vercingetorix
Registration: Sep 19, 2024 - 09:09
September 19, 2024 - 09:24
we have set up two secondary repositories. Synchronization with the primary repository works correctly.
However, with the exception of a few users on one of the repositories, all machines systematically connect to the primary server located in a different subnet.
The two secondary repositories are each in a different subnet.
We would like to understand why this is happening.
In the secondary repository condition settings in the WAPT admin console, we have entered:
"Agent IP" with the value xx.xx.xx.0\21, where 21 is the subnet mask of our subnet. Is this correct?
How can we correct the problem and test the source of the error on a client?
Have a good day.
September 19, 2024 - 10:01
Hello
, do you have HTTPS verification enabled?
If so, does the secondary repository have a valid HTTPS certificate?
https://urlreposecondaire/wapt/Packages
into your browser,
does it work?
Vercingetorix
September 20, 2024 - 10:05
thank you for your reply.
When I enter https://xx.xx.xx.xx/wapt/Packages
, I get the following error:
404 Not Found
nginx/1.24.0.
Thank you in advance for any further information.
Have a good day.
Vercingetorix
September 20, 2024 - 10:12
For your information, the verify_cert in wapt_get.ini is set to zero.
[global]
use_hostpackages=1
repo_url=https://xxx-xxxxx-wapt/wapt
wapt_server=https://xxx-xxxxx-wapt
verify_cert=0
max_gpo_script_wait=180
pre_shutdown_timeout=180
hiberboot_enabled=0
use_repo_rules=1
allow_remote_reboot=1
allow_remote_shutdown=1
[repo-sync]
enable_remote_repo = True
local_repo_path = C:\Program Files (x86)\wapt\repository\wapt
local_repo_time_for_sync_start = 20:00
local_repo_time_for_sync_end = 05:30
local_repo_sync_task_period = 25
local_repo_limit_bandwidth = 4
remote_repo_dirs = wapt,waptwua,wapt-host
Vercingetorix
September 20, 2024 - 10:38
Also included in the nginx-erros.log log file is the nginx-erros.log file
I'm getting the following error:
2024/09/20 10:32:15 [error] 3000#2012: *6 CreateFile() "C:/WAPT/wapt/Packages" failed (3: Le chemin d’accès spécifié est introuvable), client: xx.xx.xx.xx, server: _, request: "HEAD /wapt/Packages HTTP/1.1", host: "xx.xx.xx.xx"
It's not looking in the correct directory, C:/WAPT/wapt/Packages, instead of C:\Program Files (x86)\wapt\repository\wapt
as indicated in wapt_get.ini.
I'm looking for where this information is located in the INI files, but I can't find it.
September 20, 2024 - 12:45
The value of local_repo_path in the config file must have been changed afterwards and nginx didn't see it as a result.
You should force the reinstallation of the "tis-remote-repo-nginx" package.
Note: We also released the package https://wapt.tranquil.it/store/fr/tis-remote-repo-http to replace nginx and which is more efficient.
Vercingetorix
September 20, 2024 - 2:23 PM
I had a problem in my nginx.conf configuration file.
Who had root paths with c::wapt
location ~ ^/(wapt/waptsetup-tis.exe|wapt/waptagent.exe|wapt/waptdeploy.exe)$ {
                root "C:/Program Files (x86)/wapt/repository/wapt";
            location ~ ^/(wapt/.*|wapt-host/.*|wads/.*|waptwua/.*)$ {
After the modification, it works.
Vercingetorix
September 20, 2024 - 2:26 PM
before marking the post as resolved (which it is),
I would like more information about the tis-remote-repo-http package.
Two questions:
Is it more efficient for performing updates?
To implement it, can I uninstall the nginx package and install this one instead, and it will work?
Or is there also some configuration required?
Thank you in advance for your previous and future answers.
Have a good day.
September 20, 2024 - 3:22 PM
It's more efficient in terms of throughput.
Indeed, we encountered problems with nginx on Windows; the throughput was really poor.
Normally, if you install tis-remote-repo-http, it will uninstall nginx (it conflicts) and replace it without needing any reconfiguration.
Vercingetorix
September 23, 2024 - 10:32
Hello, thank you
for all these helpful answers which are helping us improve our use of the tool.
We installed the new recommended package and removed the nginx one.
Everything works, except for a small number of agents.
We stopped and restarted the wapt service.
Is there a reason why it remains on the primary server and doesn't go to the secondary repository?
Thank you in advance for your latest feedback.
Have a good day.
