[RESOLVED] Waptexit
CyrilM
Registration: May 2, 2022 - 10:28
September 10, 2024 - 11:17
I'd like to use the `propose-upgrade` command to execute a `waptexit`.
I need to know the available options, please.
My ultimate goal is to restart the computer after forcing a `waptexit`.
My package launches an HTA interface; it has a message and a countdown timer.
At t=0, the `waptexit` is launched from the HTA, and when it finishes, the PC restarts (shutdown with a timer and a planned comment - using JavaScript in the HTA to launch `waptexit` and the shutdown).
I just need an option to restart after a `waptexit`; otherwise, the idea would be to check if the process is still active and restart when it's no longer running, but I don't think that's ideal.
CyrilM
September 19, 2024 - 12:57
- Installed WAPT version: 2.5.5.15697
- Server OS: Debian
- Administration/package creation machine OS: Windows 10 and 11
I haven't received an answer to my previous question, but I'm making progress anyway. :D
And I'm encountering another problem:
When I try to install a package from the command line via a batch file or scheduled tasks, I get this error
(from the batch file): 401 client error: could not verify your access level for that URL
(from the task scheduler): return code 2147943691 (I saw online that it's a permissions issue)
Command line executed: wapt-get.exe -S -f install sdis77-tache-maj-NEXSIS
I've raised the permissions to the maximum and am using the System account.
Do you have any idea what the problem might be, please?
September 20, 2024 - 1:07 PM
Good morning
The options are documented here:
https://www.wapt.fr/fr/doc/wapt-console ... it-utility
Furthermore, there is:
https://www.wapt.fr/fr/doc/wapt-console ... se-feature
waptpython -c "from waptservice.enterprise import start_waptexit ;start_waptexit('',{'only_priorities':False,'only_if_not_process_running':True, 'install_wua_updates':False,'countdown':300},'schtask')"
which I think should be useful in your case
CyrilM
September 24, 2024 - 08:07
Thanks for the feedback.
I'll try the command; however, it only partially answers the question.
Is it normal not to be able to execute this command line from a task or batch script:
September 24, 2024 - 11:59
If you go through
-S
The installation goes through the service, so it requires authentication. Therefore, it won't work as a scheduled task.
Use in this case:
-D
tells the wapt-get command to bypass the service and connect directly.
The scheduled task, however, will need to be launched as administrator.
blemoigne
Registration: July 17, 2020 - 11:29
September 24, 2024 - 12:08
Cyril,
Here are the two commands launched as the system account via psexec; do not use -S:
C:\Windows\system32>wapt-get install -S -f tis-test
Waptservice User: SYSTEM
Server: https://srvwapt.blemoigne.lan
Server CABundle: C:\Program Files (x86)\wapt\ssl\server\srvwapt.blemoigne.lan.crt
Server client certificate: C:\Program Files (x86)\wapt\private\71253c6c-f412-455b-a907-93b10ce07490.crt
Server client key: C:\Program Files (x86)\wapt\private\71253c6c-f412-455b-a907-93b10ce07490.pem
Failed to login with Kerberos: 403 Client Error: Restricted access.
WRONG_PASSWORD_USERNAME Self service authentication failed for manage-w10$: ("('socket ssl wrapping error: [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get local issuer certificate (_ssl.c:1147)',)",)
 for url: https://127.0.0.1:8088/login
Password:
C:\Windows\system32>wapt-get install  -f tis-test
[DEBUG] Logging TWaptwuaLog with level=debug to C:\Program Files (x86)\wapt\log\waptwua.log
install using WAPT packages tis-test
Results :
 === install packages ===
  tis-test [x64_fr_PROD]         | tis-test (0-3)
CyrilM
September 24, 2024 - 2:48 PM
Thank you gentlemen for your replies.
The scheduled task worked correctly with the -D parameter instead of -S.
I will also test with pscexec.
Many thanks for your help. :D
