[RESOLVED] WAD Deployment - No more network devices
Vercingetorix
Registration: Sep 19, 2024 - 09:09
October 4, 2024 - 11:04 AM
we are trying to deploy Windows 11 on our PCs using WADs.
Our setup consists of a primary server on one LAN
and a secondary repository on another LAN.
We have a DHCP server on each LAN.
When we try to upload the image to the primary server via IPXE from a PC on the secondary repository's LAN, we get the following results:
The IP address assigned by DHCP is indeed on the secondary repository's LAN.
The ipxe.efi file is successfully downloaded from the primary server, and this happens twice!
We get a message:
IPXE initializing devices ok.
Then it goes wrong:
FEATURES: DNS HTTP ISCSI TFTP VLAN SRP AoE EFI Menu
could not boot image: Error 0x7f048207 (https://ipxe.org/0x7f048207)
No more network devices.
Can you help us with this problem?
As a follow-up question, do we need to point the "Boot Server Hostname" to the main server in DHCP?
Have a good day.
October 7, 2024 - 11:35
Hi Marc,
could you try replacing the ipxe.efi file with snponly.efi [1]?
snponly.efi is based on the EFI BIOS network drivers and works better. Now, ipxe.efi should only be used on machines that don't support snponly.efi.
Regards,
[1] https://www.wapt.fr/fr/doc/wapt-wads.ht ... ftp-server
Vercingetorix
October 8, 2024 - 10:06 AM
where can I find the snponly.efi file?
I only have undionly.kpxe and ipxe.efi in /var/www/wads/pxe.
Do we need to download the tis-compile-ipxe package for this?
Have a good day.
October 8, 2024 - 10:33
Vercingetorix wrote: ↑Oct 8, 2024 - 10:06 I only have undionly.kpxe and ipxe.efi under /var/www/wads/pxe.
Normally, if you are up to date, you should find the file in /opt/wapt/wads/pxe/snponly.efi
Latest version of wapt: 2.5.5.15697 (20422a0b)
Vercingetorix
October 8, 2024 - 11:13
I should have started with this: we're on version 2.4...
So can we use SnOnly with this version?
Thank you.
October 8, 2024 - 9:21 PM
the best solution would be to upgrade. Otherwise, you can download the server's .deb file (version 2.5) and extract the file from it.
Vercingetorix
October 10, 2024 - 1:59 PM
we upgraded to version 2.5.
The result is:
a DHCP IP address,
NBP filename is spnonly.efi
NBP file downloaded successfully.
IPXE initializing devices... OK.
Then,
Nothing to boot: No such file or directory (https://ipxe.org).
At the DHCP level, we have rules 067 with:
EFI/Boot/bootmgfw.efi
http://xx.xx.xx.xx./api/v3/baseipxe?keymap=fr
http://xx.xx.xx.xx./api/v3/baseipxe?uef ... &keymap=fr.
October 10, 2024 - 3:43 PM
Vercingetorix wrote: ↑Oct 10, 2024 - 1:59 PM At the DHCP level, we do have rule 067 with:
I didn't understand that part of your message
If you are in spnonly.efi, you are normally not in "EFI/Boot/bootmgfw.efi".
Can you specify which DHCP server to use?
Alternatively, could you also send a screenshot of your DHCP configuration?
Vercingetorix
October 10, 2024 - 4:58 PM
this is a bit confusing for us.
Attached is our Windows 2019 DHCP configuration.
2024-10-10 16_52_29-10.63.32.15 - Remote Desktop Connection.png (17.49 KB) Viewed 10209 times
Vercingetorix
October 10, 2024 - 5:09 PM
extended options
2024-10-10 17_07_51-10.63.32.15 - Remote Desktop Connection.png (18.51 KB) Viewed 10208 times
