Hello everyone,
I've had a Rustdesk server installed for quite some time now, and I've seen that agent deployment is now possible with a WAPT package.
Currently, I'm using it on demand with the information in the binary name.
I suspect I need to enter the server information in the "rustdesk.cfg" file within the template, but in what format?
Thank you.
[SOLVED] tis-rustdesk-config-template
- WAPT Expert
I used the example from the documentation to create the cfg, here https://github.com/techahold/rustdeskin ... ll.sh#L276
Rustdesk accepts the cfg format like this:
hostname = '192.168.1.1'
apiurl = ''
pubkey = glob.glob('/opt/rustdesk/*.pub')[0]
key = open(pubkey,'r').read()
config = {"host":hostname,"relay":hostname,"key":key,"api":apiurl}
rustdesk_list = list(base64.b64encode(json.dumps(config,separators=(',', ':')).encode('utf-8')).decode('utf-8').replace('=',''))
rustdesk_list.reverse()
rustdesk_cfg = ''.join(rustdesk_list)
print(rustdesk_cfg)
rustdesk.exe --config JIDEZOD79ZED?- sfonteneau
- WAPT Expert
The cfg file actually contains the server's public key, yes.
The code here is fundamentally executed on the server, yes.
So, this code needs to be executed server-side, which will generate the configuration ID?
Then, this ID needs to be added to the rustdesk.cfg file of the template?
To deploy the configuration to the clients?
Sorry, I'm trying to understand how it works.
- WAPT Expert
To put it simply
On your own machine, in a Python script, you can run this:
Simply replace "ABCDABCDABCDABCDABCDABCDABCDABCDABCDABCDABCDABCD" with the content of your Rustedesk server's advertisement
and replace 192.168.1.1 with the IP address of your Rustdesk server
The print command will display the cfg
import base64
import json
# read from /opt/rustdesk/*.pub
key = "ABCDABCDABCDABCDABCDABCDABCDABCDABCDABCDABCD"
apiurl = ''
print('CFG:')
print(rustdesk_cfg)
- WAPT Expert
Launch the update_package command (from the console).
The GUI will ask you for the cfg file.
- WAPT Expert
