[SOLVED] Adding a non-msi or non-exe file to a package
flipflip
Registration: May 31, 2022 - 09:05
October 9, 2024 - 3:18 PM
Hello everyone,
I'm finally getting started with creating Wapt packages, and my first one is very simple. It consists of copying a file (a batch script) into a folder created specifically for this purpose.
In PyScripter, I add it to my project and in the `install()` function of `setup.py`, I copy it using `filecopyto()`
And the setup.py code
    # Utilise l'uninstall créé par le msi
    if isfile(r'c:\cygwin\unins000.exe'):
        run(r'"c:\cygwin\unins000.exe" /verysilent')
        # Supprime le paquet de l'installation wapt
        softs = installed_softwares('cygwin')
        if softs:
            for soft in softs:
        # Purge des répertoires cygwin et cygwin64
        if isdir(r'c:\cygwin'):
            remove_tree('c:\cygwin')
        if isdir(r'c:\cygwin64'):
            remove_tree('c:\cygwin64')
    path = makepath(programfiles, 'xxx', 'Backup')
    mkdirs(path)
    filecopyto(r'backup_nomade.bat', path)
    pass
When I launch the installation via "Run configuration" I get the error
  File "E:\waptdev\hil-robocopy-nomade_0_Windows_DEV-wapt\setup.py", line 27, in install
  File "C:\Program Files (x86)\wapt\setuphelpers.py", line 601, in filecopyto
    raise FileNotFoundError('filecopyto: Cannot copy file %s: file not found' % filename)
FileNotFoundError: filecopyto: Cannot copy file backup_nomade.bat: file not found
FATAL ERROR : None : None
Exit code:  3
I couldn't find in the documentation how to use a file within a package that isn't an MSI or an EXE. Is it possible, or do I have to use an MSI file?
Thanks in advance,
Philippe.
October 9, 2024 - 5:24 PM
Hi Philippe,
in your screenshot you added the file to the PyScripter project.
Actually, to put the file in the package, you need to copy it to c:\waptdev\mypackage next to the setup.py script. :-)
flipflip
October 10, 2024 - 09:07
Hello, thank you for your reply.
Okay, I thought adding it to PyScripter automatically added it to the package's development directory.
Philippe.
October 10, 2024 - 3:28 PM
Hi Philippe,
thanks for the feedback! :-) You can now give free rein to your creativity!
I'm marking the topic as resolved.
