Update_package proposal for Screenpresso
Answer
jlatieule
Registration: July 3, 2019 - 9:18 AM
October 7, 2024 - 1:13 PM
Hello team,
Three or four years ago I created a package for Screenpresso with the addition of the update_package function.
Since the MSI file version wasn't correctly indicated in the file, I used a workaround by downloading the EXE version, extracting it, and then deleting the EXE file
Can you add it to the package?
The code could be improved, but as it stands it works perfectly.
At home I kept the comments dating back to the time when I was using the mobile application.
It's probably a KO, but I kept it as a souvenir as an internal example
    version = control['version'].split('-',1)[0]
##    print('Desinstallation version EXE avant déploiement version portable')
##    if isdir(makepath(programfiles,'Learnpulse','Screenpresso')):
##        print('The directory exists')
##        print('Desinstallation de Screenpresso')
##        run('"C:\Program Files\Learnpulse\Screenpresso\Screenpresso.exe" -uninstall pf -silent')
##    print('Suppression de la version portable')
##    remove_tree( makepath('C:','ProgramData','Screenpresso'), ignore_errors=True )
##    print(u'Ajout de démarrage automatique')
##    registry_set(HKEY_LOCAL_MACHINE, r"Software\Microsoft\Windows\CurrentVersion\Run",'Screenpresso','"C:\Program Files\Learnpulse\Screenpresso\Screenpresso.exe" run --hideworkspace')
    # Suppression du démarrage auto de l'ancienne version à créer
    print('Installation de Screenpresso format MSI')
    install_msi_if_needed("Screenpresso.msi",killbefore="screenpresso")
##    print('Installation de Screenpresso format EXE')
##    install_exe_if_needed("Screenpresso.exe",'/install pf /silent',key='Screenpresso',min_version=version,killbefore=['Screenpresso.exe'],accept_returncodes=[4])
##    print('Copie pour utilisation application portable')
##    mkdirs(makepath ('C:','ProgramData','Screenpresso'))
##    filecopyto('Screenpresso.exe',makepath ('C:','ProgramData','Screenpresso'))
##    create_shortcut(r"C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Screenpresso.lnk" , r"C:\Program Files\Learnpulse\Screenpresso\Screenpresso.exe")
    for soft in installed_softwares('Screenpresso'):
def session_setup():
##    print('Ajout au démarrage de session pour version portable')
##    registry_setstring(HKEY_CURRENT_USER, r"Software\Microsoft\Windows\CurrentVersion\Run",'Screenpresso','"C:\ProgramData\Screenpresso\Screenpresso.exe" --portablemode --hideworkspace', type=REG_SZ)
##    # A FINALISER
##    print('Suppression au démarrage de session')
##    registry_deletekey(HKEY_CURRENT_USER, r"Software\Microsoft\Windows\CurrentVersion\Run",'Screenpresso')
##    registry_deletekey(HKEY_CURRENT_USER, "Software\\Microsoft\\Windows\\CurrentVersion\\Run",'Screenpresso')
    remove_user_programs_menu_shortcut('Screenpresso')
def update_package():
    # Version MSI correcte depuis 12.2023, code à faire évoluer
    #print(get_product_props('Screenpresso.msi')['version'])
    try:
        import BeautifulSoup
    except:
        import bs4 as BeautifulSoup
    import re
    proxies = {}
    if isfile(makepath(user_local_appdata(),'waptconsole','waptconsole.ini')):
        proxywapt = inifile_readstring(makepath(user_local_appdata(),'waptconsole','waptconsole.ini'),'global','http_proxy')
        if proxywapt :
            proxies = {'http':proxywapt,'https':proxywapt}
    # Recherche et téléchargement de la dernière version de ScreenPresso
    os.chdir(os.path.dirname(__file__))
    page = wgets('https://www.screenpresso.com/fr/telechargement-msi',user_agent='Mozilla/5.0 (Windows NT 6.1; Win64; x64)',proxies=proxies)
    # Téléchargement du MSI
    bs = BeautifulSoup.BeautifulSoup(page, features="html.parser")
    url32 = bs.find(title = u"Cliquez ici pour télécharger")["href"]
    print(u'Telechargement de Screenpresso MSI')
    print (url32)
    wget(url32,'Screenpresso.msi',proxies=proxies)
    print(u'Recherche numéro de version (celui du MSI est incorrect)')
    url32 = bs.find(role = "button")["href"]
    #print ("Chemin vers la version : %s" % url32)
    version = (
        url32.split('screenpresso-')[1]
        .split('/')[0]
        .replace('-', '.')
    # Changement de version du paquet
    if Version(version) > Version(control.get_software_version()):
        print("Mise à jour de la version logicielle (de: %s à: %s)" % (control.get_software_version(), Version(version)))
        package_updated = True
        print("Version du logiciel est déjà à jour (%s)" % Version(version))
    control.set_software_version(version)
##    # Validating or not update-package-sources
##    return package_updated
##if __name__ == '__main__':
##    update_package()
System and Network Administrator at Domitia Habitat
blemoigne
Registration: July 17, 2020 - 11:29
October 11, 2024 - 10:38
Hi @jlatieule,
Have you tried this one? https://wapt.tranquil.it/store/fr/tis-screenpresso
Bertrand
jlatieule
October 11, 2024 - 5:12 PM
Yes, and it simply installs a basic executable file
blemoigne
October 11, 2024 - 6:05 PM
Hi Joël,
I don't know if you're familiar with this interface: https://luti.tranquil.it/
You can track package builds as soon as a developer updates an application.
Screenpresso is one of these tracked packages and therefore already has an update_package() function. The update_package() function is now defined in a separate file (update_package.py instead of setup.py).
Have a good weekend,
Bertrand
Answer
