I have a problem with a workstation; waptexit does not start even though there are pending installations.
I completely uninstalled and reinstalled the agent, but it didn't change anything.
The workstation is a Windows 11 IoT Enterprise (23H2)
Here is the part of the log that corresponds to this step:
2024-10-31 09:16:33,558 [wapttasks MainThread 7032] INFO Service Configuration: {'config_filename': 'C:\\Program Files (x86)\\wapt\\wapt-get.ini', 'waptservice_user': None, 'waptservice_password': None, 'MAX_HISTORY': 30, 'waptservice_port': 8088, 'dbpath': 'C:\\Program Files (x86)\\wapt\\db\\waptdb.sqlite', 'loglevel': 'warning', 'log_directory': 'C:\\Program Files (x86)\\wapt\\log', 'waptserver': <WaptServer https://srvwapt.MONDOMAINE.local verify_cert=False client_cert_path=None>, 'hiberboot_enabled': False, 'max_gpo_script_wait': 180, 'pre_shutdown_timeout': 180, 'log_to_windows_events': False, 'allow_user_service_restart': False, 'signature_clockskew': 21600, 'notify_user': False, 'waptservice_admin_filter': True, 'enable_remote_repo': False, 'local_repo_path': 'C:\\Program Files (x86)\\wapt\\repository', 'local_repo_sync_task_period': '2h', 'local_repo_time_for_sync_start': None, 'local_repo_time_for_sync_end': None, 'local_repo_limit_bandwidth': None, 'wol_port': '7,9', 'wol_relay': False, 'service_auth_type': 'waptserver-ldap', 'verify_cert_ldap': False, 'waptservice_poll_timeout': 10, 'waptupdate_task_period': '120m', 'download_after_update_with_waptupdate_task_period': True, 'forced_installs_task_period': '2m', 'reconfig_on_network_change': False, 'websockets_verify_cert': False, 'update_server_status_on_connect': False, 'loglevel_waptcore': None, 'loglevel_waptservice': None, 'loglevel_waptws': None, 'loglevel_waptdb': None, 'loglevel_websocket': None, 'loglevel_waitress': None, 'loglevel_wapttasks': None}
2024-10-31 09:16:33,558 [wapttasks MainThread 7032] INFO Starting task queue
2024-10-31 09:16:33,558 [wapttasks WaptTaskManager 5100] INFO Wapt tasks management initialized with C:\Program Files (x86)\wapt\wapt-get.ini configuration
2024-10-31 09:16:33,559 [wapttasks MainThread 7032] INFO Tasks queue running
2024-10-31 09:16:33,560 [wapttasks MainThread 7032] INFO Starting waitress waptservice on port 8088
2024-10-31 09:16:33,571 [wapttasks MainThread 7032] INFO Waptservice stopped
File "<string>", line 2304, in <module>
File "C:\Program Files (x86)\wapt\lib\site-packages\waitress\__init__.py", line 13, in serve
server = _server(app, **kw)
File "C:\Program Files (x86)\wapt\lib\site-packages\waitress\server.py", line 78, in create_server
last_serv = TcpWSGIServer(
File "C:\Program Files (x86)\wapt\lib\site-packages\waitress\server.py", line 244, in __init__
self.bind_server_socket()
File "C:\Program Files (x86)\wapt\lib\site-packages\waitress\server.py", line 361, in bind_server_socket
self.bind(sockaddr)
File "C:\Program Files (x86)\wapt\lib\site-packages\waitress\wasyncore.py", line 396, in bind
return self.socket.bind(addr)
OSError: [WinError 10013] Une tentative d’accès à un socket de manière interdite par ses autorisations d’accès a été tentée
Exception at 01082433: EPyWindowsError:
OSError: [WinError 10013] Une tentative d’accès à un socket de manière interdite par ses autorisations d’accès a été tentée.
2024-10-31 09:16:33,577 [wapttasks SocketIOClient 4768] INFO Starting socketio on "https://srvwapt.MONDOMAINE.local:443" Thread id 4768
2024-10-31 09:16:33,580 [wapttasks SocketIOClient 4768] INFO Socketio connection params have changed. Socketio needs reconnect
2024-10-31 09:16:33,580 [wapttasks SocketIOClient 4768] INFO Creating socketio client: https://srvwapt.MONDOMAINE.local:443 client auth cert: ('C:\\Program Files (x86)\\wapt\\private\\ln2380.MONDOMAINE.local.crt', 'C:\\Program Files (x86)\\wapt\\private\\ln2380.MONDOMAINE.local.pem') proxies: None verify_cert: False
2024-10-31 09:16:33,581 [wapttasks SocketIOClient 4768] INFO Connecting Socketio to https://srvwapt.MONDOMAINE.local:443
2024-10-31 09:16:33,600 [wapttasks WaptTaskManager 5100] INFO Core Configuration: {'wapt_base_dir': 'C:\\Program Files (x86)\\wapt', 'waptserver': <WaptServer https://srvwapt.MONDOMAINE.local verify_cert=False client_cert_path=C:\Program Files (x86)\wapt\private\ln2380.MONDOMAINE.local.crt>, 'config_filename': 'C:\\Program Files (x86)\\wapt\\wapt-get.ini', 'proxies': {'http': '', 'https': ''}, 'repositories': [<WaptRepo https://srvwapt.MONDOMAINE.local/wapt verify_cert=False client_cert_path=C:\Program Files (x86)\wapt\private\ln2380.MONDOMAINE.local.crt>, <WaptHostRepo https://srvwapt.MONDOMAINE.local/wapt-host for host_id ln2380.MONDOMAINE.local >], 'personal_certificate_path': '', 'public_certs_dir': 'C:\\Program Files (x86)\\wapt\\ssl', 'packages_cache_dir': 'C:\\Program Files (x86)\\wapt\\cache', 'dbpath': 'C:\\Program Files (x86)\\wapt\\db\\waptdb.sqlite', 'use_http_proxy_for_repo': False, 'use_http_proxy_for_server': False, 'limit_bandwidth': None, 'locales': ['fr'], 'custom_tags': [], 'packages_whitelist': None, 'packages_blacklist': None, 'maturities': ['PROD'], 'host_uuid': 'ln2380.MONDOMAINE.local', 'use_fqdn_as_uuid': True, 'use_hostpackages': True, 'use_ad_groups': False, 'use_repo_rules': True, 'host_profiles': [], 'host_organizational_unit_dn': 'OU=PG,OU=AUTOMATICIENS,OU=MAUPAS,OU=LA NORMANDISE,DC=MONDOMAINE,DC=local', 'host_ad_site': None, 'waptaudit_task_period': '1d', 'hiberboot_enabled': 0, 'max_gpo_script_wait': 180.0, 'pre_shutdown_timeout': 180.0, 'uninstallkey_timeout': 120, 'check_certificates_validity': True, 'token_lifetime': 86400, 'trust_all_certs_in_pems': False, 'include_dmi_inventory': True, 'include_wmi_inventory': True, 'wapt_temp_dir': None}
2024-10-31 09:16:33,600 [wapttasks WaptTaskManager 5100] INFO Wapt tasks queue started
2024-10-31 09:16:33,628 [wapttasks SocketIOClient 4768] INFO WS read loop for 120s
