Problem with packet size greater than 99 MB
knpc
Registration: Nov. 20, 2015 - 4:40 p.m.
September 22, 2016 - 9:46 PM
When I try to import from the internet or even from a file, I get an error message for files larger than 99 MB.
I am using a 2008 R2 Datacenter server - the repository folder is on a different disk than the one containing the base installation
The error message is attached:
WAPT error
WAPT error
wapt.JPG error (24.6 KB) Viewed 9058 times
Do you have any ideas?
THANKS
Knpc
Challans Town Hall
September 23, 2016 - 11:04
if it consistently fails at 100MB, in my opinion you need to look at the web server, there might be a restriction.
knpc
September 28, 2016 - 3:05 PM
I say BRAVOOOO!
Here's some help with resizing:
https://piermick.wordpress.com/2012/08/ ... dans-iis7/
For 2 GB, enter: 2147483648
Thanks again for your invaluable help.
