Good evening,
I'm using schtasks to perform a DELETE operation, but I don't know how to verify if the task to be deleted actually exists.
If I run the deletion and the task has already been deleted, the package correctly throws an error.
How can I check for the presence of a scheduled task with wapt?
Check for the presence of a scheduled task
- WAPT Expert
Hello Joel,
There's the `task_exists` function which returns whether the item exists or not (you need the full path if there's a directory). For example:
Note: the function launches a simple schtasks /query
setuphelpers.task_exists(r'TVT\tvsuupdatetask')Sincerely,
