WADS on Windows 11 24H2
Answer
flo777
Registration: February 23, 2022 - 9:35 PM
November 12, 2024 - 10:29
I'm trying to deploy Windows 11 24H2 via WADS.
When I boot from the USB drive generated via the WAPT console, with Secure Boot enabled, an error message appears immediately: WinPE cannot start.
If I disable Secure Boot, the Windows 11 installation doesn't work, because Windows 11 24H2 cannot be installed without Secure Boot.
Any solutions?
I'm using WAPT 2.5.
Florian
November 12, 2024 - 11:01 PM
have you changed the template for 24h2 (see here):
viewtopic.php?p=14546?
Note: For Windows 11, the PC must be able to perform a secure boot, but if it's not enabled, that's fine.
flo777
November 13, 2024 - 6:41 PM
Thanks for the clarification, indeed the template is the problem; but the installation fails after disk partitioning, even on the basic template... I'll wisely stick with 23h2 until Microsoft fixes the issues.
Answer
