Server OS: Debian 12
Target operating systems: Windows 10
Os Machine administration: Win server 2022
We have only recently acquired WAPT Entreprise. We are still in the learning phase.
We deployed our operating system using WAPT, installing the Office 2019 Pro package (custom configuration.xml file with our license). Until recently, this worked perfectly, but we've been getting an error message:
- Error during initial installation:
Erreur lors de l'installation de ['lgd-microsoft-office-2019-professional(=16.0.10415.20025-18)']: erreurs dans les paquets [[PackageRequest(package='lgd-microsoft-office-2019-professional',version=(Version('16.0.10415.20025'), 18),architectures=['x64'],locales=['fr'],maturities=['PROD'],tags=['windows-10', 'win-10', 'w-10', 'windows10', 'win10', 'w10', 'windows', 'win', 'w'],min_os_version=Version('10.0.19045'),max_os_version=Version('10.0.19045')), PackageEntry('lgd-microsoft-office-2019-professional','16.0.10415.20025-18' architecture='x64',maturity='PROD',target_os='windows'), 'Traceback (most recent call last):\n File "C:\\Program Files (x86)\\wapt\\common.py", line 5348, in install\n result = self.install_wapt(p.localpath,\n File "C:\\Program Files (x86)\\wapt\\common.py", line 4328, in install_wapt\n raise e\n File "C:\\Program Files (x86)\\wapt\\common.py", line 4235, in install_wapt\n exitstatus = setup.install()\n File "C:\\Windows\\TEMP\\waptfe7ihpew\\setup.py", line 29, in install\n File "C:\\Program Files (x86)\\wapt\\common.py", line 4165, in new_func\n return func(*args, **kwargs)\n File "C:\\Program Files (x86)\\wapt\\setuphelpers_windows.py", line 1689, in install_exe_if_needed\n run(r\'"%s" %s\' % (exe, silentflags), accept_returncodes=accept_returncodes, timeout=timeout, pidlist=pidlist)\n File "C:\\Program Files (x86)\\wapt\\waptutils.py", line 2177, in run\n raise CalledProcessErrorOutput(proc.returncode, cmd, \'\'.join(output))\nwaptutils.CalledProcessErrorOutput: Command \'"setup.exe" /configure configuration.xml\' returned non-zero exit status 202.\nOutput:\n']]
self._run()
Exception: Erreur lors de l'installation de ['lgd-microsoft-office-2019-professional(=16.0.10415.20025-18)']: erreurs dans les paquets [[PackageRequest(package='lgd-microsoft-office-2019-professional',version=(Version('16.0.10415.20025'), 18),architectures=['x64'],locales=['fr'],maturities=['PROD'],tags=['windows-10', 'win-10', 'w-10', 'windows10', 'win10', 'w10', 'windows', 'win', 'w'],min_os_version=Version('10.0.19045'),max_os_version=Version('10.0.19045')), PackageEntry('lgd-microsoft-office-2019-professional','16.0.10415.20025-18' architecture='x64',maturity='PROD',target_os='windows'), 'Traceback (most recent call last):\n File "C:\\Program Files (x86)\\wapt\\common.py", line 5348, in install\n result = self.install_wapt(p.localpath,\n File "C:\\Program Files (x86)\\wapt\\common.py", line 4328, in install_wapt\n raise e\n File "C:\\Program Files (x86)\\wapt\\common.py", line 4235, in install_wapt\n exitstatus = setup.install()\n File "C:\\Windows\\TEMP\\waptfe7ihpew\\setup.py", line 29, in install\n File "C:\\Program Files (x86)\\wapt\\common.py", line 4165, in new_func\n return func(*args, **kwargs)\n File "C:\\Program Files (x86)\\wapt\\setuphelpers_windows.py", line 1689, in install_exe_if_needed\n run(r\'"%s" %s\' % (exe, silentflags), accept_returncodes=accept_returncodes, timeout=timeout, pidlist=pidlist)\n File "C:\\Program Files (x86)\\wapt\\waptutils.py", line 2177, in run\n raise CalledProcessErrorOutput(proc.returncode, cmd, \'\'.join(output))\nwaptutils.CalledProcessErrorOutput: Command \'"setup.exe" /configure configuration.xml\' returned non-zero exit status 202.\nOutput:\n']]
self._run()
Exception: Erreur lors de l'installation de ['lgd-microsoft-office-2019-professional(=16.0.10415.20025-18)']: erreurs dans les paquets [[PackageRequest(package='lgd-microsoft-office-2019-professional',version=(Version('16.0.10415.20025'), 18),architectures=['x64'],locales=['fr'],maturities=['PROD'],tags=['windows-10', 'win-10', 'w-10', 'windows10', 'win10', 'w10', 'windows', 'win', 'w'],min_os_version=Version('10.0.19045'),max_os_version=Version('10.0.19045')), PackageEntry('lgd-microsoft-office-2019-professional','16.0.10415.20025-18' architecture='x64',maturity='PROD',target_os='windows'), 'Traceback (most recent call last):\n File "C:\\Program Files (x86)\\wapt\\common.py", line 5348, in install\n result = self.install_wapt(p.localpath,\n File "C:\\Program Files (x86)\\wapt\\common.py", line 4328, in install_wapt\n raise e\n File "C:\\Program Files (x86)\\wapt\\common.py", line 4235, in install_wapt\n exitstatus = setup.install()\n File "C:\\Windows\\TEMP\\waptfe7ihpew\\setup.py", line 29, in install\n File "C:\\Program Files (x86)\\wapt\\common.py", line 4165, in new_func\n return func(*args, **kwargs)\n File "C:\\Program Files (x86)\\wapt\\setuphelpers_windows.py", line 1689, in install_exe_if_needed\n run(r\'"%s" %s\' % (exe, silentflags), accept_returncodes=accept_returncodes, timeout=timeout, pidlist=pidlist)\n File "C:\\Program Files (x86)\\wapt\\waptutils.py", line 2177, in run\n raise CalledProcessErrorOutput(proc.returncode, cmd, \'\'.join(output))\nwaptutils.CalledProcessErrorOutput: Command \'"setup.exe" /configure configuration.xml\' returned non-zero exit status 202.\nOutput:\n']]- Error during another attempt:
Installing: setup.exe (16.0.10415.20025)
File "C:\Windows\TEMP\wapt3tn64l92\setup.py", line 29, in install
File "C:\Program Files (x86)\wapt\common.py", line 4165, in new_func
File "C:\Program Files (x86)\wapt\setuphelpers_windows.py", line 1689, in install_exe_if_needed
run(r'"%s" %s' % (exe, silentflags), accept_returncodes=accept_returncodes, timeout=timeout, pidlist=pidlist)
File "C:\Program Files (x86)\wapt\waptutils.py", line 2177, in run
waptutils.CalledProcessErrorOutput: Command '"setup.exe" /configure configuration.xml' returned non-zero exit status 202.
Output:
Output:
