[SOLVED] Error Downloading WsusScan
MPI
Registration: Nov 14, 2024 - 08:47
November 14, 2024 - 09:47
I am installing Windows updates on my WAPT server.
Features :
- Server version 2.5.5.15640
- server running Rocky 8
- machines running w11 23h2
- formerly a wsus
- Wuauserv service is down
- wsusscan status: ok, already up to date
But I encounter an "error downloading wsusscan" error when I launch the search for Windows updates to apply.
You will find the task logs below.
Ensure wuauserv Auto Update option is disabled
Scanning with windows updates rules:
 "direct_download":false,
 "default_allow":true,
 "include_potentially_superseded_updates":false,
 "filter":"Type='Software' or Type='Driver'",
 "download_scheduling":"1d",
 "install_scheduling":null,
 "install_delay":"2d",
 "postboot_delay":"10m",
 "user_locale":1033
Downloading wsusscn2.cab file from https://wapt.domain/waptwua/wsusscn2.cab
re-enabling wuauserv previous state: 0
404 Client Error: Not Found for url: https://wapt.domain/waptwua/wsusscn2.cab.sha1
  File "<string>", line 1939, in run
    self._run()
  File "C:\Program Files (x86)\wapt\waptservice\enterprise.py", line 288, in _run
    self.result = wua.install_updates(self.force, uuids=self.uuids)
  File "C:\Program Files (x86)\wapt\waptwua\client.py", line 1660, in install_updates
    self.scan_updates_status()
  File "C:\Program Files (x86)\wapt\waptwua\client.py", line 1212, in scan_updates_status
    self.update_wsusscan_cab()
  File "C:\Program Files (x86)\wapt\waptwua\client.py", line 1076, in update_wsusscan_cab
    return self.download_wsusscan_cab()
  File "C:\Program Files (x86)\wapt\waptwua\client.py", line 1072, in download_wsusscan_cab
    raise e
  File "C:\Program Files (x86)\wapt\waptwua\client.py", line 1060, in download_wsusscan_cab
    sumwsusscn2 = wgets('%s.sha1' % cab_location, requests_session=session).decode('utf8').strip()
  File "C:\Program Files (x86)\wapt\waptutils.py", line 1188, in wgets
    r.raise_for_status()
  File "C:\Program Files (x86)\wapt\lib\site-packages\requests\models.py", line 1021, in raise_for_status
    raise HTTPError(http_error_msg, response=self)
requests.exceptions.HTTPError: 404 Client Error: Not Found for url: https://wapt.domain/waptwua/wsusscn2.cab.sha1
None : None
    self._run()
    raise e
blemoigne
Registration: July 17, 2020 - 11:29
December 16, 2024 - 10:00
it seems WUA isn't enabled on the server side. You'll need to rerun /opt/wapt/waptserver/scripts/postconf.sh and enable WUA.
Have a good day,
Bertrand
