I am following the documentation below: https://www.wapt.fr/fr/doc-2.5/wapt-ser ... er-install
And I'm encountering a problem running the post-installation on RHEL 8.8:
[user@srvwapt ~]$ sudo /opt/wapt/waptserver/scripts/postconf.sh --cspn-toe
Waptserver
Version: 2.5.5.15697-20422a0b
File "/opt/wapt/waptserver/scripts/postconf.py", line 1316, in <module>
main()
File "/opt/wapt/waptserver/scripts/postconf.py", line 885, in main
ensure_postgresql_db(db_name=server_config['db_name'], db_owner=server_config['db_name'], db_password=server_config['db_password'])
File "/opt/wapt/waptserver/scripts/postconf.py", line 592, in ensure_postgresql_db
migrate_db_if_needed()
File "/opt/wapt/waptserver/scripts/postconf.py", line 514, in migrate_db_if_needed
if get_current_running_postgresql_version() < Version('10'):
File "/opt/wapt/waptserver/scripts/postconf.py", line 71, in get_current_running_postgresql_version
version = run("sudo -iu postgres psql -t -c 'SHOW server_version;'").split('(',1)[0].strip()
File "/opt/wapt/waptutils.py", line 2177, in run
waptutils.CalledProcessErrorOutput: Command b"sudo -iu postgres psql -t -c 'SHOW server_version;'" returned non-zero exit status 126.
Output:/etc/profile: line 31: /usr/bin/id: Permission denied
/etc/profile.d/colorgrep.sh: /usr/libexec/grepconf.sh: /bin/sh: bad interpreter: Permission denied
/etc/profile.d/colorxzgrep.sh: /usr/libexec/grepconf.sh: /bin/sh: bad interpreter: Permission denied
/etc/profile.d/colorzgrep.sh: /usr/libexec/grepconf.sh: /bin/sh: bad interpreter: Permission denied ┌────────────────────────────┐
/etc/profile.d/lang.sh: line 11: /usr/bin/sed: Permission denied │ SELinux correctly │
/etc/profile.d/which2.sh: line 4: /bin/readlink: Permission denied │ configured for Nginx │
/etc/profile.d/which2.sh: line 4: /bin/basename: Permission denied │ reverse proxy │
/etc/profile: line 31: /usr/bin/id: Permission denied │ │
/etc/profile.d/colorgrep.sh: /usr/libexec/grepconf.sh: /bin/sh: bad interpreter: Permission denied │ │
/etc/profile.d/colorxzgrep.sh: /usr/libexec/grepconf.sh: /bin/sh: bad interpreter: Permission denied ├────────────────────────────┤
/etc/profile.d/colorzgrep.sh: /usr/libexec/grepconf.sh: /bin/sh: bad interpreter: Permission denied │ < OK > │
/etc/profile.d/lang.sh: line 11: /usr/bin/sed: Permission denied └────────────────────────────┘
-bash: /bin/psql: Permission deniedCode: Select all
[user@srvwapt ~]$ sudo -iu postgres psql -t -c 'SHOW server_version;'
10.23
Thank you in advance
