[SOLVED] WAPT Console Problem on Ubuntu
thomas789
Registration: May 31, 2021 - 3:44 p.m.
November 25, 2024 - 10:23
INFO:
WAPT Server version: 2.5.5.15640
WAPT Agent version: 2.5.5.15640
WAPT Console version: 2.6.0.16552-49ddf2d3
Version of my admin PC: Ubuntu 24.04.01
I am encountering two errors on my WAPT console:
- The first is the message "Unable to find Python DLL /opt/wapt/lib/libpython3.9.so" when I use the Update package function (as soon as I click the button) Launch the update package for the selected packages)
- The column display malfunctions as soon as I move them (see attached image)
Screenshot from 2024-11-25 10-16-35.png (30.51 KB) Viewed 4992 times
Thank you in advance, best regards.
November 25, 2024 - 10:27
Hi Thomas,
did you successfully update the Wapt agent on the machine using the console?
Regards,
thomas789
November 25, 2024 - 1:09 PM
this did indeed fix the update package issue, but not the column display problem.
Regards.
December 2, 2024 - 12:07 PM
Hi Thomas,
I'm submitting an internal ticket to track the display bug. We plan to work on refining the interface in the coming months, and the team will be able to look into it.
In the meantime, I'm marking this topic as resolved.
Regards,
