[RESOLVED] Problem using the search bar after deploying Firefox ESR package 128.5.0-109
fobrian
Registration: Sep 26, 2024 - 09:35
November 28, 2024 - 10:10
I don't know if others on this forum are also experiencing this issue, but since the start of the Firefox ESR 128.5.0-109 package rollout, some of our users have been reporting problems when entering content in the Firefox search bar.
Once the search is entered, it has no effect.
Changing the default search engine (a problem mainly observed with Google) resolves the issue depending on the selected engine.
Resetting the caches or repairing Firefox ESR does not fix the problem.
I'm going to revert to version 128.4.0-109 using a custom package and see if I can report the problem to the Mozilla developers.
Different problems also seem to be reported in discussions on the official Mozilla website:
https://connect.mozilla.org/t5/discussi ... td-p/79615
Thank you in advance.
Fred
November 29, 2024 - 5:59 PM
Hello Frédéric,
indeed the upstream Firefox version seems to have a change in behavior. But since the issue will probably be addressed quickly by Mozilla, I don't think it's relevant to force the change to network.http.http2.allow-push in the wapt package itself.
Otherwise, for those using SSL interception with Firefox version 128.4, you need to force the parameter network.http.http2.allow-push=true in the prefs.json file [1].
I'm marking the topic as RESOLVED.
Best regards,
[1] https://bugzilla.mozilla.org/show_bug.cgi?id=1933747#c4
