Following the BitLocker audit package update, I'm getting an error without having touched the code inside (I initially modified it to add our certificate and then tried again without making any changes). In both cases, I get this error:
https://srv-wapt.XXXX.dom/wapt/XXXX-audit-bitlocker_10.6.0-41_windows_10.0_PREPROD_f0fbc8a41032a3c9a76b1ee74e56ccfb.wapt : 9384 / 9384 (100%) (594 KB/s)
Erreur lors de l'installation de ['XXXX-audit-bitlocker(=10.6.0-41)']: erreurs dans les paquets [[PackageRequest(package='XXXX-audit-bitlocker',version=(Version('10.6.0.0'), 41),architectures=['x64'],locales=['fr'],maturities=['PROD', 'PREPROD'],tags=['windows-10', 'win-10', 'w-10', 'windows10', 'win10', 'w10', 'windows', 'win', 'w'],min_os_version=Version('10.0.26100'),max_os_version=Version('10.0.26100')), PackageEntry('XXXX-audit-bitlocker','10.6.0-41' maturity='PREPROD',target_os='windows'), 'Traceback (most recent call last):\n File "C:\\Program Files (x86)\\wapt\\common.py", line 5348, in install\n result = self.install_wapt(p.localpath,\n File "C:\\Program Files (x86)\\wapt\\common.py", line 4328, in install_wapt\n raise e\n File "C:\\Program Files (x86)\\wapt\\common.py", line 4142, in install_wapt\n setup = import_setup(setup_filename)\n File "C:\\Program Files (x86)\\wapt\\waptutils.py", line 1589, in import_setup\n py_mod = imp.load_source(modulename, setupfilename)\n File "imp.py", line 171, in load_source\n File "<frozen importlib._bootstrap>", line 702, in _load\n File "<frozen importlib._bootstrap>", line 671, in _load_unlocked\n File "<frozen importlib._bootstrap_external>", line 839, in exec_module\n File "<frozen importlib._bootstrap_external>", line 976, in get_code\n File "<frozen importlib._bootstrap_external>", line 906, in source_to_code\n File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed\n File "C:\\WINDOWS\\TEMP\\wapt_8oj1pba\\setup.py", line 153\n certs_path.extend(x for x in get_code_signing_cert() if x not in certs_path)\n ^\nIndentationError: expected an indented block\n']]
self._run()
Exception: Erreur lors de l'installation de ['XXXX-audit-bitlocker(=10.6.0-41)']: erreurs dans les paquets [[PackageRequest(package='XXXX-audit-bitlocker',version=(Version('10.6.0.0'), 41),architectures=['x64'],locales=['fr'],maturities=['PROD', 'PREPROD'],tags=['windows-10', 'win-10', 'w-10', 'windows10', 'win10', 'w10', 'windows', 'win', 'w'],min_os_version=Version('10.0.26100'),max_os_version=Version('10.0.26100')), PackageEntry('XXXX-audit-bitlocker','10.6.0-41' maturity='PREPROD',target_os='windows'), 'Traceback (most recent call last):\n File "C:\\Program Files (x86)\\wapt\\common.py", line 5348, in install\n result = self.install_wapt(p.localpath,\n File "C:\\Program Files (x86)\\wapt\\common.py", line 4328, in install_wapt\n raise e\n File "C:\\Program Files (x86)\\wapt\\common.py", line 4142, in install_wapt\n setup = import_setup(setup_filename)\n File "C:\\Program Files (x86)\\wapt\\waptutils.py", line 1589, in import_setup\n py_mod = imp.load_source(modulename, setupfilename)\n File "imp.py", line 171, in load_source\n File "<frozen importlib._bootstrap>", line 702, in _load\n File "<frozen importlib._bootstrap>", line 671, in _load_unlocked\n File "<frozen importlib._bootstrap_external>", line 839, in exec_module\n File "<frozen importlib._bootstrap_external>", line 976, in get_code\n File "<frozen importlib._bootstrap_external>", line 906, in source_to_code\n File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed\n File "C:\\WINDOWS\\TEMP\\wapt_8oj1pba\\setup.py", line 153\n certs_path.extend(x for x in get_code_signing_cert() if x not in certs_path)\n ^\nIndentationError: expected an indented block\n']]
self._run()
