problem with remote-repo-nginx
Answer
Renaud Villet
Registration: January 23, 2020 - 2:12 PM
October 18, 2024 - 09:02
I'm having trouble adding a repository to a Windows machine using the remote-repo-nginx package.
After installing the package, the repository synchronizes correctly, but the nginx service doesn't start; it's not found because it's clearly not installed. However, there were no errors during the package installation.
Thank you for your help
October 18, 2024 - 10:34
Hi Renaud,
sorry, but with so little information it's going to be difficult to help...
Wapt version, etc. See forum rules. Log file, etc.
Regards,
Renaud Villet
October 18, 2024 - 12:08
So, actually, not much more information...
version 2.5.5.15697 Enterprise edition
on the machine, the nginx-access, nginx-errors and waptnginx logs are empty,
nothing particular to report in the waptservice logs,
sorry I don't really see what more information to give you, except that we had the same problem on 2 separate machines (Windows server 2022)
fschelfaut
Registration: Nov 7, 2024 - 12:22
November 27, 2024 - 09:02
package tis-remote-repo-nginx is deprecated for the Windows version. Could you please test with its replacement , tis-remote-repo-http, and then let us know your feedback?
Flavien,
December 2, 2024 - 12:00
Hi Renaud,
to add to Flavien's answer, version 2.5.5 of wapthttpserver (which is included in the new package) has a limitation compared to WADS. So if you want to use WADS on remote sites, you need to upgrade to WAPT version 2.6.
Regards,
Answer
